Poor Plumber's Pluto, a novel DIY project
Some of you may be familiar with Siegfried Linkwitz's web site and his Pluto loudspeaker system.
Pluto specs
The Pluto design has garnered quite a following with many having built or bought his design outright. A user/builder forum also exists.
I've developed a novel TL design utilizing the PLuto drivers with powered sub to fill in the low end that can be built for about 10% of what the Pluto sells for assembled. Some have called it but* ugly. Others have expressed an interest.
Pluto+ from Wood Artistry
Attached is a picture of the PPP pair. PM me for details, more pics and test data. Some of the test data shows direct comparisons between published Pluto data and the PPP. You'll be surprised how similar the PPP data is!
If you're interested in building your own PPP, contact me.
The Pluto is omni out to 3kHz. Being able to cross the Aurasound NSW2 mid/tweeter at 1kHz allows the woofer to operate in its pistonic band. So having the woofer facing forward shouldn't really mess with the polar response.
Is that frequency response gated?
Does having the TL terminus off to one side of the woofer asymmetrically affect the polar response? Would it make sense to make the left and right channels symmetrical for peace of mind (and possibly aesthetics).
Roger
The test I show is not gated and thus the favorable results below 150 hz.
Having the terminus asymetrical isn't affecting the polar response significantly. The terminus power response is down about 10 dB from the mid/woof.
I could easily make them symmetrical with a few adjustments of the pipe fittings which BTW, are not glued (yet).
PM me with your email address for the polars I show compared to SL's.
A Destitute Plumber's Pluto?
Just wondering if - for reasons of impecunity - one could utilise (say)
HiVi drivers like the B2S and either the M5N / M6N / M6A?
All with a cute copper-coloured face. (WAF)
The xMax is down in all cases, but perhaps that wouldn't matter in a smaller room?
The freq ranges are suitable, same impedences, and you could blank off a section of your pipe to account for the differing woofer Vas, right?
As I say, just a thought experiment ...
cheers
Doug
The Seas bass/mid driver was used for two important reasons. It's Qts is about 0.6 which is in the ideal range for TL's.
Second, its size allows the back side behind the flange to fit nicely into the rubber coupling.
You'll have to check the HiVi drivers for proper fit. Also recommend you visit www.quater-wave.com for info. in TL design to size the pipe's diameter and length.
I used 4 inch ABS easily available here in the states at the local Home Depots or plumbing supply houses.
Not really. The frequencies at which diffraction would happen in this configuration are high enough that the driver is producing a very narrow beamwidth- thus the "edge" is minimally illuminated.
I'm also not sure that diffraction is necessarily a problem, however baffle step would occur at a fairly high frequency and should be pretty easy to compensate if it was felt to be a problem. Perhaps I shouldn't say easily, but it would be realitively inexpensive as the components would won't cost as much as those that would be needed for lower frequencies.
Best Regards,
TerryO
For aesthetic reasons, could the TL pipe originate at the bottom rear of the primary pipe and then ascend straight up and terminate behind it (preserving length of course)? It might make the design a little sleeker looking without the TL pipe on the side. Just a thought.
Also, any reason not to go with a passive/active sub or subs? The system would have a little more oomph in larger rooms and the total cost would still be very reasonable (plus you'd have a single straight pipe, and shorter too).
The woofer/mid is located approx. 25% along the TL length is one way to mitigate response ripples - the biggest battle a TL designer has to fight. Since my pipe was small to start with, I couldn't realistically, taper the pipe at the end like many TL wooden cabinet designs do, so I went with the location of the woofer mid as shown.
One of the bases houses a 100 watt plate amp and a ten inch down-firing sub. See attached pic.
