This tends to indicate that to be audible, jitter, admittedly random, requires to be of the order of hundreds of nanoseconds.
Yes, random jitter isn't really of much interest. But thanks for providing the link.
Jitter is simply flavour of the month as regards features of audio systems which can be seized upon by the marginally-informed or the dissembling to blame for imaginary deficiencies or differences in systems. Nobody seems to notice or care that the recordings are made using systems whose performance is no better than the playback systems they are complaining about.
Then your playback system is really no better than those used in recording studios for monitoring? From the way you've described yours, I'd hazard its considerably worse. On my el-cheapo system I can hear which recordings are pants and which aren't. One example of a pants recording is:
Amazon.com: The Very Best of MTV Unplugged: Various Artists: Music
Fortunately that's the exception not the rule.
I think that what is driving DiyHifi is, for the large part, narcissism. Most of what they are doing is ego-driven. Very little on the site is about finding solutions, most of it is about finding problems, and they're not fussy about whether they're real or not. It's a lot easier to sit in the audience and heckle than it is to get on stage and perform.
Yes. What you write about that forum is true of life in general - for the large part people's lives are ego-driven. Of course that's not invalidating people's lives, any more than it invalidates the evidence and arguments presented on that forum to say its ego-driven.
Audio frequency design is the 4rse-end of electronic design. Even a SMPS is harder to build than an audio amp. All the guys with two braincells to rub together go into advanced telecomms, DSP or imaging. Cellular phones. Satellite communications. Wireless broadband. HD video.
So those of us who have worked in AF design are down to just the one braincell then?
Why not simply move on from this fruitless discussion of RFI and jitter in obsolescent systems and concentrate on the appreciation of low-jitter solid state players or buffering burst-download USB3 DACs which will inevitably replace the current generation of systems as night follows day. The easiest way out of this argument is not to settle it by blind testing, but by making widely available systems in which jitter is reduced below the point of any imaginable audibility.
Flawed premise leads to flawed conclusion.
You evidently don't understand what is meant by data-dependent jitter.
Data-dependent jitter is non-periodic. Trivially, if the signal is a square wave then there can be no data-dependent jitter. If the transitions are pulled out of place by a burst of ones or a burst of zeros, this is called data-dependent jitter. It might have frequency content in the case of a continuous recorded tone of constant amplitude, but not in the case of music. It's not described as random because of it's relationship to the data, but because the data itself is effectively random in terms of bursts of ones and zeros, it's random in effect.
You have described my argument as 'straw man', but as far as I can see you have no argument to offer at all. JosephK himself was at a loss to describe a mechanism whereby this jitter could be audible. The fact that it is there does not correlate it with any audible effect. You are the one suggesting that it is audible, it is incumbent on you to demonstrate that it is.
Please bear in mind that this is your obsession, not mine. I have taken the time to research at least some evidence which is relevant. Before you start accusing me of trolling, produce for me at least one piece of evidence which shows that all the effort on your part is not going into producing hot air.
w
w
Waki, one question- I haven't seen the JosephK post you're talking about. What is it that he's measuring the jitter of? The clock signal at the DAC? Or somewhere upstream? That's kinda important for context...
I seem to recall he's analysing the SPDIF datastream for jitter. Measuring jitter in the clock signal at the DAC would tell us mostly about the performance of its PLL.
Yes, but jitter at the clock input of the DAC is what primarily determines sonics. So if that's the case, the paper Waki cited was inapt- they're jittering the DAC clock, a much more severe test.
Any reference you have for this? I'd appreciate a headsup - sonics of jitter are less of an issue IME than common-mode RF.
It would be related - via the transfer function of the PLL. Waki's paper points out that random jitter is inaudible way beyond the performance of the average SPDIF receiver IC. So that leaves ISI-induced jitter to be explored.
Inapt isn't quite right, it would just indicate that jitter on the SPDIF would have to be higher still to have more than 250nS residual. Given that the jitter we're talking about is tens of pS, one could reasonably hope it would be less than this at the DAC, and additionally as JK points out, it is high frequency, where the filtering effect of the PLL is most effective.
w
w
... additionally as JK points out, it is high frequency, where the filtering effect of the PLL is most effective.
Yes which leads him to seriously question whether this whole jitter thing is perhaps a red-herring and that the sonic differences are something else. Like common-mode RF for example. This (CMRF) would also explain reports of USB cables sounding different when async USB is used - no means there for jitter to affect the sound.
I wasn't aware of these. You can get asynch USB? I'll have a look...
w
There's a thread about it over on Diyhifi too. Charles Hansen admits sound quality differences for his QB-9 asynch DAC with different USB cables. He says he doesn't know why.
I have learned a lot from this thread.
Tubelab, I don't personally know anybody who would do that but I am sure there are 11 meter guys who would do anything if you gave them the idea that they could tear up more equipment over a longer distance by doing it. I have seen car trunks full of batteries and big capacitors just to give them the power they need to ruin everything electrical for everybody they possibly can and go mobile with it.
The jitter he is talking about is of the order of tens of pS.
Why not read this:-
Detection threshold for distortions due to jitter on digital audio
Old stuff. I've read it in the past (dont feel like reading it again).
Do they say which was the MINIMUM jitter to which the listeners compared?
I bet it was 50ps or higher. In short, the listeners lacked a good reference.
Newer test have showed that jitter in the 5/10s ns range is indeed audible.
BTW RF and other noise creates RANDOM jitter, which is harder to measure but easier to spot by the ear (= worse).
w
Yes, with custom drivers (the hiface) or firmware (es. wavelength audio).
I don't know how you'd know it'd be random. That's certainly one possibility but its not the only one. Also common-mode RF's manner of affecting the sound is not necessarily via corrupting the clock. Its just as likely to get into output stage opamps and drive them into non-linearity.
Just to clear something up, the correct way to control ringing overshoot when doing signal integrity work etc is to use terminations, paralell, series or thevorin, end, middle etc. It may be a minor point but using attenuation is an incorrect term
You terminate to match impedences, you terminate to absorb excess nenergy put into the line, blah blah blah.
An excellent reference on how to terminate properly is Chapter 6, High Speed Digital Design, Howard Johnson.
A great way of reducing these problems is to use a signal rise time that is comesurate with the clock speed, ie one that is not to fast, in fact the slower the better.
USB cables sound different! I'd like to see some shots of waveforms from both the transmitor and reciever end.
In regard to SPDIF its not the case that 'the slower, the better'. Reducing the rise time means greater ISI and it follows that the data-dependent jitter will increase. Hawksford wrote in quite some detail about that in his paper in collaboration with Julian Dunn.
As with most things, there's a compromise to be struck between the bandwidth and the jitter.
You'll presumably be only inspecting the differential mode noise if looking with a scope and hence miss the probable root cause of the sound degradation.
- General Interest
- Everything Else
- RF & Audio
