I've just bought a Sony HA-55 phono head amp, and there's a problem with the left channel. Somehow the bass is missing and I'm wondering what can cause that in a head amp (there might also be a minor volume difference).
I've got the schematics (and parts list) so I can test if all components are working according to specifications.
Would appreciate however if somebody could point me in the right direction of where to start.
Thanks!
Thanks!
I would assume given that it is over 30yrs old it is due for full electrolytic cap replacement at minimum..
http://www.thevintageknob.org/SONY/sonyesprit/HA55/HA55.html
http://translate.google.com/translate?hl=en&sl=ja&u=http://mijinko.jp/component/HA-55.html&ei=rWRRTeHyNsWBlAftrtn2Cg&sa=X&oi=translate&ct=result&resnum=1&ved=0CBkQ7gEwADgU&prev=/search%3Fq%3DSony%2BHA-55%26start%3D20%26hl%3Den%26sa%3DN%26prmd%3Divns
I second that. Also, it might be a good idea to post the schematic here if you're going to get into it. The quality of advice that can be given rises exponentially once there's a schematic.
Any idea how I can upload a PDF file? (schematics)
Depending on the size of the pdfs you can just attach them using the "manage attachments" button under advanced editing. I replied to your PM just a little while ago.. 😀
Hi Orson,
Check your email for my response. I believe a cap replacement as stated is in order. Specifics are in my email response.
Good Luck!
Good Luck!
- Analogue Source
- Sony HA-55 Head Amplifier
