Envying
Why don't I have an attic where such treasure tubes are hidden? Moaning... Heart breaking...
This my Phono preamp "Tweety", which I built two years ago. Tweety has a passive RIAA filter, a first stage ECC83 and second stage with ECC83 in SRPP. Left on the photo is "Granny", the Power Supply, Tweety is on the right.
Maarten
ps. Details on the homepage: http://www.platenspeler.com
Maarten
My 813 SE amp.
More pic's for my 813 amp.Please propose your precious idea , and thanks you ! http://www.balstudio.com/813/813page1.htm
Ahh just back from the bench, fix0r3d up Frankenhouse... changed around some HF dampening type stuff, now it's solid as a block of granite (err, well I forgot to test it with a capacitor, come to think of it). Frequency response something like 5Hz to 40kHz at flea-power, with a slight peak around 10Hz (I wonder why), a small downstep around 3kHz, smooth roll-off above 20 or 30kHz (-3dB @ 40k), and a slight peak amidst the falloff at 380kHz.. heh. Full power of 14W (6 ohm load on the 8-ohm tap) 50Hz-30kHz (uh.. I think.. forgot to test max. power at HF).
Damping factor has got to be good, output dropped all of .05V in response to changing the Rl from 8 to 6 ohms...
Squarewave looks great over the whole band, even looks remotely square at 20kHz. It's a little lumpy, that smooths out with 680pF across the NFB resistor.. but that's so little I didn't solder it in.
Anywho, it looks cheezy but works nice:
All this porn has inspired me to want to build a nice looking tube amp. Might start with pre-amp for my gainclone.
PP built by Igor
Hi guys!
I see a lot of great amps here. So, mine seems to be modest one. But anyway..
This is my latest amp working now. It is very close to Wiliamson schematic. Ulta Linear, push-pull, 70 Watts. Tubes KT88 for output, 6H6 Driver, 12AX7 for phase splitter and preamp.
All transformers toroidal and self constructed. Toroids is one of mine principal positions. 🙂
I'm novice here, so don't kick me too much!
Igor.
Hi guys!
Igor.
Igor,
When you want to attach pictures:
- only one at a time.
- do NOT use the preview button.
- there's a size limit as well 100Kb and 800*? 1000?
Cheers,😉
Igor,
Cheers,😉
Hi Igor...
would love to see your pics..If you can't get them smaller...mail em to me...and I'll adapt them for you..
Bas
Bas
Bas Horneman said:Hi Igor...
Bas
Hi Bas,
Thank you. I sent 2 files 24k and 64k separately. May be my proxy server rebell. I'd send it for you, but e-mail here doesn't support file attachments, while your real address hidden. My addr igormak@hotmail.com. I may send you files would you write me smth. Through my hotmail acc I send files without problems.
Thanks for help.
igor.
Here i try attach again..
Hi Igor,
Interesting and nice looking amp 🙂 I can see your attachments OK.
Your comments about toroidal transformers: Do you wind them yourself? Output transformers?
dhaen said:Hi Igor,
Hi John,
I'm really sorry posting several same pics! I'd send others, but have a some douts in their delivery. Hope, same pics will be deleted.
About transformers: all them (3) are toroidal. Power 16 cm2, output 8cm. Power range on 60watts 20Hz-20kHz without feedback. Anyway, there is slight fb finally approx 8 db.
Amp working already 1.5 years and I happy with it. 🙂
Thank's Igor
- Tubes / Valves
- Photo Gallery
