Hello,
I am looking to put some spare drivers to use--Hiquphon OW2's and Vifa P17's. Traditionally I have done high simple two-ways using 1st order xovers but am now looking to try out "something new" and possibly a MTTM design using said drivers above.
Plain and simple, I just can't find a lot of info, good or bad, about the MTTM configuration. I have read that long ago, that alignment was mandated initially for THX certified speakers. Nowadays, the only "high end" speaker I can find using MTTM are the large (and expensive) Dynaudio speakers which also use 1st order xovers.
Any comments, good or bad about using MTTM? Lobing better or worse then MTM? Wider/narrower sweet spot? I will be using 1st order, like the Dynaudios, however the tweeters will be set back into the cabinet to try and achieve better time alignment.
Any comments good, bad, or indifferent about MTTM's would be most appreciated....
Thanks in advance.
Thanks in advance.
Look at your overall plan. First order x-overs are not easily done, and I believe not practical for a MTM or MTTM due to the lowish x-over point that you would need due to spacing of the P17s.
You should read D'Appolito's paper on MTMs.
Multiple tweeters, unless they are very and I mean VERY close together will have lobing issues and destructive interference/comb filtering at off angles.
If you crossover appropriately you should be just fine with only one tweeter, unless your mids are louder than the tweeters. One alternative might be to trim/crop the flanges of the OW2s so they fit closer together.
This is incorrect. Dynaudio runs one tweeter full range. You can learn more by reading here:
Dynaudio Confidence C4 loudspeaker | Stereophile.com
Using two tweeters can also provide valuable re enforcement at low frequencies where most tweeters suffer from excursion limits and distortion. Combining this with the reduction in high angle vertical off axis energy that would otherwise result in ceiling and floor reflections and you have significant improvements in SQ overall.
Center to center distance concerns are generally vastly overstated in DIY circles. Blanket rules of thumb cannot substitute for accurate phase difference calculations accounting for acoustic offsets, crossover phase, driver phase response, and time of flight differences. If you frequently listen from a ladder or while lying on the floor close to the speakers - you might have a problem. Otherwise, accurate calculations and measurements are necessary before one can rule out one approach over another.
Well, I've done at least 2-dozen 1st order xover speakers, so *I* think they are easy. And there are a ew of examples of MTM's (and MTTM's like the Dynaudios) using them. The case in point however for MTM 1st order are the Dunlavy's and eventually the Duntech's which they later morphed into being. Both brands were/are known to be some of the finest transducers in the world and they are again 1st order, WMTMW.
I'm not worried at all about the drivers I have being able to handle 1st order. The P17's are the "darlings" of the 1st order community for those on a budget. Very smooth overall. The Hiq OW2 have real cajones. I've crossed as low as 2.4kHz 1st order with no audible stress, however 2.7kHz and up are where they shine 1st order.
My worry is that I've never done either an MTM or MTTM so I'm unfamiliar with what the best practices are and also why I can only find 1 manufacturer in the world (Dynaudio) doing a MTTM 1st order.
Thanks a lot for that link, interesting read. So they "cap off" one tweeter at 8kHz to avoid top octave lobing. Hmmmm, would have to ponder that in the design.
No need to reinvent the wheel. Look carefully at the placement of the Dynaudio drivers and their crossover points and you should wind up with a similar result. The Hiquphons and Vifas are great - I've used them extensively myself. As for only finding 1 manufacturer using twin tweeters (aside from the myriad of line source designs out there) there are several manufacturers who have employed the technique successfully. This one is fairly well known and there's a "high end" design by a manufacturer other than Dynaudio that escapes me at the moment.
Floorstanding Speakers : Millennia M80 v3 - Axiom Audio
hello JJ...
First older filter is mostly a myth
The step provided in the stereophile review (joined below) is far from the first order type. They even add that the boomers are in reverse polarity !
So, don't start your job while taking Dynaudio as an honest example. 😉.
Coincidentally, last year I have bee listening to the big Evidence model, and I can't say that the double tweeter formula produces some combing harshness. It's very clean (but the speaker itself is a little bit boring for my taste).
hello JJ...
Incorrect. Look closely at the blue trace in figure three of the measurements section. Clearly, the "boomers" possess a first order slope (down around 6db from 200 hz to 400 hz). From the graphed response, an asymmetric crossover is likely and the effective phase difference through much of the overlapping frequencies is likely to be less than 90 degrees despite the reversed polarity. You can't deduce the crossover topology from the fact that a particular driver's terminals are reversed.
Thanks fntn! I also have used these drivers extensively too which is why I have spares! Matter of fact, this is one of my designs featured on Hiquphon's web site using OW/4:
Who sells Hiquphon dome tweeter. Where can I buy Hiquphon loudspeaker units
I have done so many 1st order 2-ways I am getting bored. Want to "broaden my horizons". MTTM will be the way I go then like the Dynaudio. Just need to start doing some planning on the xover and limit the one tweeters top end and such. Not sure if MTTM will be any better or worse then what I've done before, but how do I know if I don't try....
Sounds great 🙂
The Dynaudios are some of my favorite speakers. Keep us posted here on your progress. I'm looking forward to it.
What is the acoustical rolloff of the tweeter and woofer 2 octaves above and below the x-over point in your speakers?
6dB
Whats yours? 😉
6dB
Whats yours? 😉
How? Looks like 12 dB natural rolloff to me. How do you reduce this to 6 dB?
Hiquphon OWII (OW2) dome tweeter, technical data
Tweeters without flanges.
I recently bought a whole bunch of tweeters so I can use multiples in a project I'm planning. The thing is that they are so incredibly small and have no flange so that I can scrunch them up all nice and cozy real tight together on the baffle. It will be kind of like an array.
Hi jjkozlow,
Have you run any lobing simulations for your MTTM design? The Dynaudio Confidence C4 loudspeaker is a 2002 WMTTMW design. Stereophile: “In my approximately 3100-ft3 room, finding the positions where the Confidence C4s worked optimally was more problematic than it had been with the other speakers I've reviewed recently. In particular, getting a smooth blend between the low-bass, midbass, and upper-bass regions took much experimenting. With the C4's use of first-order crossover slopes and four drivers overlapping through much of the upper-bass region, the need to make the distances of each driver from each of the adjacent boundaries (the side and rear walls, even if the speaker's restricted vertical dispersion reduces the effects of the floor and ceiling) as different as possible becomes more complex than in the case of a speaker that uses a single woofer and a steep-slope crossover. Even when I felt I had got the Confidences optimally set up, the low frequencies were more weighty than was strictly natural. “
FROM WHAT I HAVE LEARNED: If I do not meet the MTM spacing requirements as researched by D'Appolito, then I have speaker junk because of audible lobing. I am no longer an engineer but become a "MAD MEN"*(USA TV show) that drinks scotch, smokes cigarettes, has sex with many women, and markets amplifier power cords.
It is very difficult to meet MTM spacing requirements even with a single small diameter tweeter if 4"-5" midbass are used. D’Appolito recommended a 3rd BW crossover when spacing rules are met, and LR4 if the spacing is larger than optimum.
TAKE A LOOK AT: The 94db/watt, 4-ohm, small diameter SD29RDCN tweeter with the top and bottom front plate cut down for even shorter MTM spacing. The ScanSpeak Discovery 10F4424G00 measures very well. The TangBand W5-1880 full range as a high-detail midbass. An 0.375" aluminum baffle plate with the speakers front mounted plus front wool felt around all drivers avoids reflections of rear waves common in thick 1"-1.5" wood baffles.
Biro Technology
fx = c/2 * |{[(L cos [theta])^2 + (d + L sin [theta])^2]^1/2
- [(L cos [theta])^2 + (d - L sin [theta])2]^1/2}^-1|
fx is the lowest frequency of total cancellation in Hz, [theta] is the vertical displacement (ranging from -90 deg. to +90 deg.), d is the vertical separation between the high-frequency driver and one low-frequency driver, L is the distance from the plane of the drivers to the on-axis design point, and c is the velocity of sound. For a given d, as [theta] increases in magnitude, fx decreases. Clearly, if d and [theta] are sufficiently large, it is possible that fx will occur at a frequency where
Clearly, if d and [theta] are sufficiently large, it is possible that fx will occur at a frequency where the output from the high-frequency driver is negligible, and the system response at that frequency at that listening angle will effectively drop to zero.
Biro Technology
drinks scotch, smokes cigars, has sex with many women, and markets amplifier power cords.
A day in Las Vegas at the CES. Ha!
Absolutely!
Living Voice uses 6,5" midbasses MTM and they sound very good. I can't hear any lobing that I can point.
I've though of some MTTM or MTTTM or MTTTMM configuration.
Tweeter configuration could be 2 or 3 (4ohm) domes in series, outer capped of above 8000 Hz.
Woofer config is harder. There's not too many 16 ohm woofers for DIY. 3-4 ohm load is too hard I think (two 8ohms parallel).
Is three woofers totally crab?, two 8ohms in series and third paralleled with them? It makes 5 ohm but two in series draws very little current beacuse the branch is 16 ohms. ( 8 || (8 series 8) )
Sb Acoustics has two small flanged domes and so does Peerless (ex-Vifa) if I remember. Peerless has tweeters without face plate.
- MTTM advantages/disadvantages?
