Hifonics BX1605D repaire
relay engages. im a bit scared to push on the board again, dont want to burn anything out.
but i did notice voltage rail drop from almost 40vac per rail to 22vac per rail when i had the HIP4080 in and out. when out the rail voltage was higher, when in lower. that also seems strange. yet there is no difference in current draw.
David
I don't know why that would have changed so much. It could have been an error caused by the changing pulse width (assuming that the rail voltage is regulated).
Do you have 35v DC on the positive and negative speaker temrinals? Place the black meter probe on the secondary center tap. Place the red meter probe on the point where you need to measure the voltage.
made a nice discovery right now. remember i told you that i was reading 7VAC/3.7VDC on the positive output terminal, zero on the negative?
now i took out the 4080 and tested both terminals.
positive stayed the same, but the negative terminal has 9VAC/5VDC without the 4080 in place. what can i learn from that? maybe the FET's are bad?
I think the outputs are probably Ok. Generally, when the outputs are shorted, the speaker terminals are either shorted to the secondary CT or they have full rail voltage on them. When they're floating at voltages in-between the secondary CT and the rail, they are almost always OK unless they have intermittent connections on the legs of the transistors (most commonly broken at the body of the transistor).
gosh these class d amps are complicated haha..
i got 3 lm393's in the amp, is there any way to check them? and the op amps in the pre amp section? im just gonna test every thing to make sure i got no bad parts in there..
AND ive found a shorted diode! 🙂
here is a photo attached. diode is in the red circle..
David
