Hello all
I recently got this amp very cheap...
So im interested in replacement for STK2038B coz this original one is not working...
I couldnt find that chip here on the market (Serbia)
All i was able to find is STK2038 IIcl so im wondering can i use it as a replacement?
Thanks!
Thanks!
According to this: [TechAssist] Re: looking for STK2038 (or 20x8) pinout or datasheet - techassist - FreeLists , you can't ( different number of pins and probably pin-out ) it's probably easier to build a new amp module with an ic that has similar voltage requirements and power output.
The STK 2038 is notorious for failure, and when it does it often takes the voltage amp IC, AN7062 with it.
These amps are nothing particularly special to be honest.
Ye i know
Since im beginer in audio electronics i alrdy managed to fix one hitachi amp with STK ic...
This Technics amp was one of many i mean realy many fail amps with STK hybrid inside... So for start of my electronic experience all i can say is run away from STK amps as far as u can!
Hello all
Thanks!
Technics SU-Z55 chip replacement
i own this model amp..too.
but deth ic...
i replace new amplifier stk4231 ic with new board to add and some alter
and find i/o con output to stk4231 amp very nice....
and increase caps 10000mfd 63v per rail
works very fine.
cricklewoodelectronics.com list the STK2038 II but I have no idea if this is the same as the STK2038B.
I have the same problem on Technics SU-V2X, I have ordered the STK2038 but i'm not shure if it is pin compatible with the STK2038IV.
Does anyone have a datasheet of the STK2038 ?
What is the best replacement ? I would like to have class A or Technics new class A output stage. Any suggestion ?
STK2038
Hello all,
If you are repairing a SU-Z45 use the SU-Z22 schematics not the SU-Z55 schematics.
You can replace the STK2038 with a STK2038IV which is just a slightly improved version of the (mark I). But not with a STK2038 II as the pin outs are different.
You can also go one step further and replace it with a STK2048IV . The STK2048IV is the drop-in replacement for the STK2038IV.
If your amp is using a STK2038II you maybe able to replace it with a STK2048II but I have not tested this myself.
What you have to remember when buying STK's online is the old STK's were discontinued in the 1999's from what I can remember so we are now 17 years later and you are 90% of the time going to be getting a fake IC or a second hand one that has been stripped out of the amps that were returned to the manufacturers under warranty years ago chances are their outputs were blown that's why they were returned. So your best bet is to find a second hand working IC or find a repair shop that has been around for years and ask them to check in their old stuff.
In most cases the AN7060's will be undamaged by the STK blowing as they are protected by Q301 and Q302 which will need replacing.
If you are in a jam and only have AN7062's you could easily mod one and run wires to work in place of two AN7060's or use half of 2 AN7062's to replace 2 AN7060's be careful you need to match the pinouts and supply voltages.
Always test the AN7060's with the STK out just to make sure that they were not the cause of the STK blowing.
I have run these technics amps and the fisher amps at full volume for 10 hours straight with no amp problems I don't stack the components so the amp's have more ventilation.
I use old Sansui 3 way speakers with quality Sansui crossovers sometimes the subs blow.
If you are in a jam and have a working mark II it maybe possible to use the mark II by doing some mod to the extra pins I read some where that the extra pins are to set some control.
I will respond to the resistor burning Thread after checking my notes
Hello all,
Hi guys,
just a quick question.
with what to replace the Q301 and Q302?
At the moment the Q301 and Q302 have the inscriptions A992 FA26.
This is maybe a stupid question but im just a noob in this kind of things.
Thanks in advance for the reply.
- Chip Amps
- Technics SU-Z55 chip replacement
