My new idea TL072+2 irf610
My new idea application,only use two same irf610 to building amp,This prevents different components due to process differences caused by different,hope someone give me some advice,^_^
attachment.php
No problem, some people might see it in one forum and not the other.
Typically amps in this forum are pretty simple class A amps . Just a quick observation. maybe a VAS/driver for the o/p transistors. There was a recent integrated front end with a discrete o/p just a few days ago. I had a quick look and did not find it there were some application notes with suggested direction and it used several different o/p transistors. I had it saved but i lost everything
in a recent computer crash. Thank god for a back up computer....
Regards, Elwood
Interesting approach. It seems to be a simplefield version of this topology (post #1):
http://www.diyaudio.com/forums/soli...h-pull-pull-like-gamnut-whats-right-name.html
check out also this thread:
http://www.diyaudio.com/forums/solid-state/66334-gamut-d200-clone.html
perhaps there are any advices to additional improove your topology.
I've been looking for a N-Channel using only a simple circuit, I see that you provide a little complicated, if it simpler, the design of my simulation is correct, but the actual application of a problem
