NEED HELP FROM YOU BRAINIACS?
Fifteen or so years ago, I read an article in hi-fi world on positioning speakers. It gave yo an equation depending on room dimensions. I still have that mag somewhere, but can't find it.The article gave you the means by measuring the room L-W. were to place your speakers what it did'nt say was the distance from back wall to the front or back of the speaker.Do any of you brainiacs know this equation and can anyone explain this for me, preferably in the old feet and inches, Being an old dunce never did the metric thing when i was at school, I would be very grateful if you would give me this knowledge kind regards and a happy new year to all banginon :deer:😀😕
any formula will be inherently flawed, it will all depend on the type of speaker/room. a starting point would be to form a triangle with you the same distance from the speakers as they are apart from each other. the center of the tweeters or fullrange cones seven feet apart and a foot or two from the rear wall with as much or more from side walls. if too bright aim them straight ahead. if not try toe in towards you. too much bass move further from the rear wall and vice versa. Some speakers require corner loading and others like open baffles need more room behind to the rear wall for the rear wave.
there are probably as many expert formulas to solve this issue as there are DIYers with the brains to deconstruct them 🙄
but it couldn't hurt to kick back and read the following at Cardas Audio
Cardas Audio
and
Cardas Audio
edit: see what happened in the 3 minutes it took to type this reply and cut/paste the above links ?
the brainiac was definitely a cute opening salvo of foreplay
thanx
Cardas Audio
and
Cardas Audio
took a glance very nice turns out i pretty much have it ok thanx again 😀
idoit what do i know
I dont build i just listen thats all i have evre done,I guess I am gonna give up now. I built this room 17 years ago I put in it what sounded good at time, its 25ft long 17ft wide back wall 15ft 6inch front. my speakers are tannoyD700 bought at the time I now am runnig a MUSICAL FIDELITY KW 550 AMP FRONT IS MUSICAL FIDELITY NU-VISTA 3D CR PLAYER NO#1 #2 IS TEAC TD CANT REMEMBER TRANSPORT MF X24DAC X-PSU 3#IS ARCAM ALPHA 5 PLUS SOUNDS Good just a big juke box really but i love it the only thing i can say is big big respect to all of you when its right STOP AND ENJOY HAPPY NEW YEAR AND ALL THAT REMEMBER ITS ALL ABOUT LISTENING PEACE OUT 😀😀😀😀
