US AMPS VLX_400
Im working on this amp and have 19.68 volts on the left channel outputs i removed all the outputs from that channel and still have the 19 volts on the output.
This is what i get on the pads for the outputs
Tip 35
1:19.93
2:37.38
3:19.80
Tip 36
1:19.83
2:-37.38
3:19.87
Any ideas on what to look for?
You have broken the audio feedback loop by removing the output transistors.
Its likely the output then has gone to one rail.
You could feed back the VAS output back into the LTP if you have a schematic to test the driver stage.
Ok I figured it out . Amp had 2 bad mpsa56's and 2 06's and also had a defective resistor.
Amp powers up and plays perfect. Now the fun of putting it back in the heatsink.
I got busy and forgot to buy the Kapton film But i have tons of brand new mica insulators which if i go that route should be fun since there is 116 transistors all together
I just repaired a US Amps amplifier a couple of days ago.... 116 transitors? Are you kidding? Mine only had like 10; but being a one channel amp there wasnt much to break. Fortunately for me it was just bad RCA jacks.
I laughed when I saw "Made in Florida". Odd. An old-time installer said these amps used to be demonstrated as mig welders using a loud input source and shorting the speaker terminals to bare metal. I didnt think TIP35/36 transitors could handle that... Then again it was a crazy ara during which car audio was more of a journey.
