What were the bass drivers in the posted pictures? I can't tell from the pics and didn't see it listed.
The bass drivers are recycled Eastech 7" from Monsoon Media 7 multimedia system. Quite a nice woofer. I'm going to use the same to fill the holes in my FonkenWoofTLs when i pull the SDX7 out for my new enclosures, and Scott has a pair in the UK (austensibly woofer support for huis uFonken)
dave
dave
...the irony being that the little uFonken actually doesn't do half bad even without them. 🙂 I did get the Eastechs going recently though, & I was really quite impressed. Nice & smooth, & plenty of detail. Good match. Once the weather improves, I'll get them into an aperiodic box which will double as stands.
As I've had a pair of the Eastech's (thx Dave!) up and running in a PP sub, (again thx!)
filling in the bottom end of my "Frugels" , I'm used to hearing a quite nice, articulate re-inforcing of the above.
How do the same drivers do in the above "Fonken" vis a vis the PP sub?
THanks, Don
THanks, Don
I'll let you know when i get around to swapping them.
dave
In reviewing plans for this build, I am having trouble making sense of the second item under Notes 2. As I read it, the part of the baffle/brace that is in contact with the magnet should be bevel cut. It's unclear, however, that this would really provide any "breathing room." Is the reference, instead, to the angled cuts from the vertical (in contact with the magnet) to the vertical at the front-most of the baffle?
I'd have more confidence moving forward, though, if I had confirmation.
The interior side of the driver cut-out should be beveled or radiused ( i.e. either 45` chamfer bit or 3/8" - 1/2" roundover )
The enclosure for 167 is certainly tall enough that the vertical driver brace can be notched to well over the cut-out diameter. The line at which the brace contacts the magnet ( and for that matter the various random openings in the braces) can be similarly beveled or radiused, but with a driver this size, I'd imagine the returned benefit to be not as significant as with 3-4" units. I generally do chamfer the holes in the braces and sand them, mostly to reduce getting slivers during assembly
I love your assembly and the picture illustrates quite a bit about this build. Thank you for your assistance.
OMG that looks beautiful inside! Certainly qualifies as Hi End to me... the thought and work needed to produce that cabinet must have been challenging. I really want to hear this design after seeing that pic... my stuff is so basic in comparison. Great work!
Zilla
Zilla
Closing on a new home this Friday. As soon as we get settled I'll be emailing for these plans. I love the look and I think they'll go nicely in our new family room.
Any objections on using these for HT use? Could I run another 167 in a sealed enclosure for a center channel?
Chris has his in a 2.0 HT. Sealed centre works fine.
dave
Looks like no one is using floor spikes with these? Are they necessary, advisable, optional, or detrimental?
Also, does mass loading the base help the sound or just the stability?
Is this (Sonic Barrier 1/2" Acoustic Foam w/PSA 18" x 24" | Parts-Express.com) suitable for use as damping material for this build?
Actually, mine do have spikes, the less than vertical appearance of mine in the enclosed image may have been "Merlot-induced"!!Looks like no one is using floor spikes with these? Are they necessary, advisable, optional, or detrimental?
Best, Don
- Full Range
- Fonken 167 enclosures build- notes
