Hi all
I have just taken apart the sub cabinet of my Logitech Z-2300 and I want to build it into my furniture to have the ugly box out of sight. Having it taken apart, I wonder if there is room for improvement.
1. could I replace the driver (it turns out it is a Tang Band W8-670Q). specs (wich mean absolutely nothing to me):
Fs = 42.95 HzRe = 7.80 ohms
Le = 7328.42 uH
L2 = 3120.63 uH
R2 = 52.25 ohms
Qt = 0.52 Qt
Qes = 0.57 Qes
Qms = 6.49 Qms
Mms = 50.81 grams
Rms = 2.112233 kg/s
Cms = 0.000270 m/N
Vas = 10.35 liters
Sd= 165.13 cm^2
Bl = 13.755757 Tm
ETA = 0.14 %
Lp(2.83V/1m) = 83.66 dB
Or could I imrove the size of the cabinet:
The original enclsure is 30,5 cm x 25cm x 25 cm (inside) = 12" x 10" x 10".
Maximum inside size of the new enclosure is 23cm x 41cm x 38cm (= 9.1" x 16,1" x 15")
The original is ported with some weird U-shaped plastic tube, diameter of the outside hole 5,3", the diameter of the tube itself is 3", the length of the tube about 22".
I hope the specialists here have some interesting things to say!
Thanks in advance!
Erik Blokpoel
Le = 7328.42 uH
L2 = 3120.63 uH
R2 = 52.25 ohms
Qt = 0.52 Qt
Qes = 0.57 Qes
Qms = 6.49 Qms
Mms = 50.81 grams
Rms = 2.112233 kg/s
Cms = 0.000270 m/N
Vas = 10.35 liters
Sd= 165.13 cm^2
Bl = 13.755757 Tm
ETA = 0.14 %
Thanks in advance!
Erik Blokpoel
Greets!
First things first, these specs are somewhat different than what is published, so are yours measured or........?
GM
nope not measured (have most of them no clue what they mean). I have the info from a forum, he seems to have measured it. Sorry I did not check with the specs of the tangband driver myself! 😱
T/S specs wrong?
Hi erikb1971,
Are the specs measured? In any case they are not the specs of a Tang Band W8-670Q. Please, see TB's website.
Hi erikb1971,
The specs seem to be measured from the original speaker: logitech w200of120-02f. I found on th einternet it was a tangband driver, but that does not seem to be the case. Again sorry for the confusion!
wow... that looks pretty impressive... but I have no clue what that means. It is bedtime in Europe, so Iam gonna take a good night sleep and study it in the morning. If Iam not able to figure out what it means I will get back 🙂 Thanks a lot for the effort!
Erik
Erik
..I wonder if there is room for improvement.
Le = 7328.42 uH
L2 = 3120.63 uH
R2 = 52.25 ohms
Qt = 0.52 Qt
Qes = 0.57 Qes
Qms = 6.49 Qms
Mms = 50.81 grams
Rms = 2.112233 kg/s
Cms = 0.000270 m/N
Vas = 10.35 liters
Sd= 165.13 cm^2
Bl = 13.755757 Tm
ETA = 0.14 %
Erik Blokpoel
Hi Eric,
Why not build a multi-folded TH using 0.5" Ply (using the driver specs here-above):
b🙂
The simplest way of doing it is using an internal volume about
20% to 30% larger with the original vent, anything more
radical may not suit any amplifier EQ.
rgds, sreten.
rgds, sreten.
Hi erik1971,
Here is the Boxplot output..........
Unfortunately, it can't show the effect of the driver's high inductance.........
GM
Hi GM,
That's correct, but how correct is that Le value to begin with? Hornresp would be better, no doubt. I often use Boxplot for a quick try, and it seems to work quite well.
Greets!
Probably way more correct than using none at all due to the mid-bass hump it causes, though with no way to know how close either of the specs posted so far may be to reality, it's all just a bunch of hand waving, so I'm inclined to just put it in the OP's desired cab and use the vent from its original cab.
WRT BoxPlot, I'm with you, it and the math routine it's apparently based on has been my default designer for all types of alignments including some horn alignments for several decades now and ticks me off no end that it won't work for long in XP Pro before shutting down.
It's only real drawback for me is its lack of inductance effects on the response and of course it calcs too long a vent for anything but an ideal uniform particle density loading, but then I was 'raised' to do final tuning in-room for best overall performance, so not a big deal, especially now that we have MJK's accurate enough software to sim high aspect ratio alignments.
On a semi-related note, the memtest86 you suggested awhile back confirmed my computer's RAM was up to par, so for awhile after was at a loss as to why mine was so slow with some of HR's plots.
Anyway, long story short, it turned out to be power supply overheating that had apparently been a problem since day one and once repaired, it now zips right along with MathCad, HR, Excel, etc. like never before, so thanks for the nudge that got me past just accepting its (sub par) performance.
GM
GM
and if I understand the boxplot correctly (and if the provided specs are correct), all I need to do is shorten the current vent tube with 3" and build the cabinet according to the sizes in de boxplot picture? Sweet!
Hi Eric,
b🙂
eeerrr.... multi folded TH..... eeerrrrr 😕 and I can't read the picture even when I enlarge it. Could you elaborate a little bit for me please?
Measuring driver parameters.
Hi erikb1971,
Yes, you can measure the Thiel/Small parameter with a simple multimeter, a small resistor and your computer as a signal generator. There are a lot of references on the web.
Here is Brian Steele's website:
The Subwoofer DIY Page - Measurements
and
Elliott Sound Products:
Measuring Loudspeaker Driver Parameters
Having that data will allow you to optimize the enclosure for this particular driver.
Hi erikb1971,
and
HA!
Bought a multimeter today (sky tronics 600.219)
Turned my iphone into an oscilator
Bought a resistor, took the stereo from the bedroom and voila!
Source Voltage Vs 0,81 Volts Source Resistance Rs 5,50 Ohms Speaker DC resistance Re 6,40 Ohms
Voltage across R
0,37 Volts Source current (DC) Is 0,07 Amps
Voltage across R at resonance Vm 0,13 Volts Current flow at resonance Im 0,02 Amps Resonance frequency Fs 41,00 Hertz
Speaker impedance at resonance (Rm) Rm 28,77 Ohms
-3dB current Ir 0,04 Amps r0 r0 2,88
-3dB voltage Vr 0,22 Volts
Fh
47,10 Hertz Fl
35,80 Hertz Fs check
41,06 Hertz
So, my first ever measuring of a speaker... now what?
Voltage across R
Fh
47,10 Hertz Fl
41,06 Hertz
HA!
Voltage across R 0,37 Volts
r0 2,88
Fh 47,10 Hertz
Fl 35,80 Hertz
Fs check 41,06 Hertz
r0 2,88
Fh 47,10 Hertz
Fl 35,80 Hertz
- Subwoofers
- refitting logitech z-2300 sub into different cabinet: room for improvement?
