The circuit was designed by Mr. Thom Kaman.
This is an all JFET line stage.
thanks circuiscc, Im in for a couple🙂
Greg,
Good catch! 🙂
I should have sent all my files to you for proof reading before posting.
Just kidding.
circuitscc
Good catch! 🙂
Just kidding.
circuitscc
circuitscc:
Would you consider offering a soft start module, preferably one capable of handling the demands of a large power amplifier? I am considering building a couple of large amps (Aleph J-X) and will probably use toroids that are in the 800 to 1000 watt range. I don't have a circuit (and lack the skills to evaluate those that are available on the web), but there might be a decent demand for a low cost, well-designed soft start pcb.
Scott
Scott
The following pictures show 3D views of my circuit boards.
Only with the help from Greg can I post them on this thread.
Thanks Greg! 🙂
Thanks Greg! 🙂
Hi Scott,
Have you tried NTC ICL (inrush current limiter)?
It is not as good as a soft starter but simple and inexpensive.
I used them in my diy power amps with good results.
Hope this helps.
circuitscc
Hope this helps.
circuitscc
Luke,
You raised a very good question.
Initially Bourns 3296 was used in the layout. It is very precise but overkill. Bourns costs USD2.50 per piece. CTS (the one in my final layout) costs only USD0.50. As there are 4 trimmers per board, savings will be USD16.00 for 2 channels. My intention is to make a LOW COST assembly that everyone could afford.
If there is enough support for this project price per (bare) board will be less than USD10. This can happen when total board area reaches 25 sq.ft.
I can buy the trimmers in the US and send to you with the boards.
circuitscc
circuitscc
ok but you get what you pay for🙂
Here in local store we can only get bournes. (that Im aware of)
Greg,
The PCBs were sent by airmail this morning.
Please drop me a line when you have received the package.
Also, you may post you feedback on the forum.
Kind regards,
circuitscc
Kind regards,
circuitscc
Greg,
Kind regards,
circuitscc
Hi circuitscc,
I just received a parcel and what a surprise, a lovely collection of PCBs. 😀
These boards look very professionally designed and manufactured, excellent work.
I was looking for the BJT Mirror Preamp circuit when I came across your recent post, sorry for missing it earlier.
What are your plans for PCBs in general? You have a very nice collection of PCBs already.
Thank you.
Greg,
I'm using Micro-Cap 9 to figure out the values of the components. Then samples will be built and tweaked with a Stanford audio spectrum analyzer to get the lowest distortion possible. If they can passed my audition test a BOM will be sent to you.
Thanks and regards.
Thanks and regards.
This thread had moved to the following location :
http://www.diyaudio.com/forums/solid-state/176674-simple-low-distortion-diy-preamp.html#post2354872
- Group Buys
- Low Cost PCB Group Buy
