Bass sounded balanced to me in Lowther room where most rooms had far to little or far too much. There were few rooms that had a balanced sound like the Lowther room. I only heard acoustic folk music in Lowther room so perhaps my assessment is unfair. I would have liked to have heard symphonic which is a good gauge to my ears, regardless things sounded nice in there. I did receive one report that upper register got hard when rock was played but I did not hear it.
Yeah, I suppose I could.
Please Jon, I would love to see some photos!
Hi Jon Ver Halen, did you get to hear any of the other rooms?
Not too much, as I was mostly attending my room.
The problem with these shows is often source material. You may walk into a room where you don't like the style of music, or the particular recording is not good, and you walk out. The next cut may make the system come alive and musical as hell, but you did not hear it and so your recollection of the room is negative. If you don't have the time to hear something you are familiar with, you have not really heard the system. So listening over time is important, and very difficult to do in the course of an event like this. I simply did not have that opportunity due to the obligations of my room.
That is actually one of the reasons I try to play some of the old war horses of the hi-end, because a lot of audiophiles know the music and can relate to how my system sounds.
excellent point, Jon - even though one can quickly get bored of overexposure to "classics", or current trends (anyone remember Sheffield Labs "I've got the music in Me"? ), at least the chances are arguably better that sonic judgments of even very short term sessions are made on a level playing field.
Then there are other factors as well that contribute to the overall impression of ease and comfort of the experience at shows like these, Without naming names ('cause it's been a couple of years and there were too many to remember), there are some rooms that you just don't want to leave, regardless of whether the program material is something you'd want on your desert island playlist - and others from which you can't escape quickly enough.
Sorry about that
Guess I was more foolish than normal this year. Watched people take a ton of pictures in my room, but I did not take any.
You can try the Stereophile blog picture, although it only shows the speakers and not the front end turntable/pre-amp set up.
Stereophile: Lowther and First Watt
Hi Jon,
Could you please reveal some details about the crossover (order, frequencies, alignment) that was used on the last Open Baffle at RMAF. I have some impression that the first order crossover was used, but that's just a guess.
Vix
Vix
Hi Jon,
Vix
The woofer low pass was set at 80 hz, 2nd order using the B5
The Lowther hi pass was set at 150 hz, 2nd order using the B5
No, this does not make any sense until you read Martin Kings article on Open Baffles describing why this does not make a hole in the mid-bass response.
The tweeter was first order passive at 10 Khz. No low pass on the Lowther. Basically a 2 uF cap, with a couple of resistors to attenuate the tweeter.
Hi Tea-Bag
Yes and No. I also made a mock-up B5, using B1 buffer blocks instead of opamps and built an active crossover. In this case i was more curious to know what exact crossover points/ slopes, Q, worked for that particular setup.
Vix
Vix
Hi Jon,
You replied while I was typing! 🙂
Thanks!
p.s. It was the Linkwitz-Riley alignment? (Or Butterworth/)
Thanks!
Forgot the Q
Hi Vix:
Forgot to tell you the Q. Used Butterworth curves for this project.
Hi Tea-Bag
Vix
Hi Vix:
Carrying the B5
Of course. Nelson has indicated shipping at the end of the month. I have a few on order for customers already.
Jon,
Are you going to carry the B5?
Dragon Solaja certainly is Dragon , when working with tubes and magnetics ........ but his name is Dragan .......
Hi Jon,
Have you heard Lowthers with Nelson's F5? I'd like to hear any thoughts on the combo?
BTW, your new speaker looks awesome indeed!
Thanks,
Jim
Thanks,
Jim
Hi Jon,
Thanks,
Jim
Hi Jim:
Thanks for the kind words. Yes, the F5 on Lowthers is an extremely transparent pairing, more than enough power, and plenty of dynamics. I do slightly prefer the slightly sweet sound of the J2 over the F5, but that is personal bias. Both are extremely fine amps.
- Full Range
- RMAF
