Well then I am stuck on how I wire up my Nady xa-900 amp and where to connect the speaker wire to what bining posts..
Yes, running the coils in parallel will result in half the impedance.
usually ch1 plus = plus ,ch 2 plus = minusWell then I am stuck on how I wire up my Nady xa-900 amp and where to connect the speaker wire to what bining posts..
if the amp has a bridge switch it should be on that,if not ypu should reverse polarety on the second channel.
a manual would be helpful
