RMI-FC100, a single stage audio power amplifier
yes, it appears to be better (sounds better and measures better) if the bias is correctly set. It deteriorates slightly if the bias is set higher. It deteriorates a lot if bias is set low.
Measure and match your Re, don't accept +-5%, not even +-1%, I go for a total spread of <0.5%
Vre should all be close to average but inevitably you will get variations some times big variations. Try to get Vre variation <=+-5%, i.e. aiming for 18mVre then accept 17mVre to 19mVre as very good matching.
16mVre to 20mVre is probably acceptable. 16mVre might be underbiased. I think it safer to increase bias for all, to achieve 17mVre to 21mVre, (18mVre+3 to -1).
Sheldon,
Roender mentioned in his BOM:
"D2, D3, D8: Green LED type LT433B or any other rectangular LED with Vf>=1.9V at If=5mA
D7, D6: BL-R5122B.RED or any other rectangular red LED"
Could you please let us know what's your choice of red LED, at what Vf and If?
Thanks.
Been out of town for awhile. Best way to answer the question is to look at this picture:http://www.diyaudio.com/forums/atta...c100-single-stage-audio-power-amplifier-4.jpg
Sheldon
Thanks, Sheldon.
I found this picture a couple of days ago which might be a better representation of the answer to my own question.
http://www.diyaudio.com/forums/atta...stage-audio-power-amplifier-rmi-fc100v1.1.jpg
But I still can't figure out what's the black thing enclosing D1, Q18 and Q21. Is it some sort of heatsink? 😀
