Do they make an output transistor that's higher wattage/amps than the
2SC5200?
sam
Try:
MJL4302A
MJL4281A
Also better than 2SC5200
You mean to parallel two 2sc5200s?
That's what I am trying not to do.
There may not be one but it would be great to find one that is 250W,20A+.
There's some mosfets with double dies that would work but trying to stay bipolar.
sam
sam
how do you intend to heat sink that? - multiple packages spread the heat for more thermal transfer efficently
Now we go back to
MJL4302A
MJL4281A
Thanks everyone for the info on a better transistor than the 2sc5200.
The MJL4281A/MJL4302A looks like a good replacement for the 2SC5200 and
2SA1943.
Would be nice if they came in an SOT227 package. This would help dissipate
the heat better.
Sam
2SA1943.
the heat better.
Sam
I would not consider these particular ONsemi devices as replacements.The MJL4281A/MJL4302A looks like a good replacement for the 2SC5200 and 2sa1943
There are other ONsemi devices that should make good replacements.
Other?
Like?
Like?
Greg -
Nice work on the tables... SOAR ??? (I give up - Google no help).
Greg -
hi sandbasser,
Thanks. 🙂
SOAR = Safe operating region
or just
SOA = Safe operating area
It looks like SOA is used more often.
regards
I think that in practical applications with single pairs. There are really only 3 types of common, economical output transistor in use. They are available in fab. variations of VCE to permit multiple arrays with much higher rails than are safe to use with single pairs.
Look closely at the specs of all the types available for the basic MJ21193/4. They vary only in Package...(that means dissipation limits with TO3, T0267 or TO247 being available,) and VCE/VCB limits -(that means numbers of units possible in a multiple array). Thermaltrak diodes are another variation
egs MJ21193, MJL21193, MJW21193, NJW21193.
It's the same deal for MJL3281/1302 and 2SC5200/A1493 groupings. There are a few different packages, VCE/VCB variations and different part numbers. eg 2SC 5198/A1491 but the basic chip and performance limits are substantially the same for each part number series.
Read the numbers...kinda similar, eh? 4281,3281,0281. Sure, they are clones of the obsolete Toshiba 2SC3281/A1302 pair.
Sanken give you an alternative with the larger format M200 outline 2SC 2922 etc and a couple of similar types. This gives best dissipation and potential power output for a single device as mt490 suggests. When thinking of pushing any transistor, regardless of die size or heatsink/backplate thermal conduction, SOA and the likelihood of exceeding is the main concern. This takes real expertise IMHO.
With not a lot of genuine alternatives, Wahab's 2 x 2SC 5200 or any TO267 pair may be the safer, higher performance and more economical plan.
Actually as I see it the major manufacturers typically have three distinct offerings of interest to audio.
1. General purpose audio output
2. Extra-linear or RET transistor
3. Motor driver applications
Number 3 has poor gain linearity and sometimes slow speed, but whether this matters depends on if you can design your topology around it or not.
Sanyo is perhaps the odd one out, they discontinued their number 2 with no true replacement in sight. Well I guess their practical replacement is ON Semi 😉
- 2sc5200
