KSA50 AMP(New production Live in...)
Hi abin
can you give this focus bigger picture about this jumper
thank you (specially what you jumper below the board)
That resistor depends on your vcc and your relay coil resistance.
I will use +-35V and relay is 275ohm so I used 500ohm 2W. for a voltage drop of 12.9V over relay.
Dissipation across resistor will be just over 1W for my application. so 2W is needed.
My relay will close and work reliably between 70% and 170% of rated voltage.
oh yes abin
i got mje 15030 & 31 ( CE & CB Voltage was 120 - 150 )
can this replace mje 15032 & mje 15033 ( CE & CB Voltage 250 ) ?
May use, but is not very ideal!
compare the de-rated SOAR of the proposed devices to that of the recommended devices and compare both to the stress they will undergo in the amplifier.
It may be that both can meet the heat & current/voltage requirement or that neither can be reliable in your implementation.
If you in China, I may deliver you a pair of ultra-large radiator fin.
48KG
niehau abin,
im in china a lot. i am very interested in your pcb, but even more in your chassi... i have address in beijing, shanghai, guangzhou and hong kong ... your choice!
id love to get access to some of the pcb and also good chassi. i am in singapore but spend lots of time in china every month. let me know....
par
meaning
how are you abin ?
Parb want to buy your pcb, heatsink & chassis
he is singaporian but always go to china
for delivery please choose the near city from yours
either in beijing, shanghai, guangzhou or hongkong
he can receive your package there
you can give offer for Parb now
(and another free pcb for me 😀, just kidding man)
niehau abin,
par
Yes, I am here in Guangzhou recently.
meaning
how are you abin ?
Thank you! ! In this way you said I would understand.
