6SN7 / 6V6 power amp : very odd behavour
I built this from scratch but it is acting very strange.
A. It sounds distorted unless you run it at ~85vac.
B. The louder the input, the higher the B+ goes and the lower the AC input current goes 😕
C. the output tube is running on the hot side.
Schematic attached.
coool! OK 1st things 1st - you need to decouple the B+ to the input tube by putting a capacitor (say, 22uf) across the supply AFTER the 680 ohm resistor.
Is your PSU REALLY half wave? Thats gotta hurt!
Anyway, no input measurements please - B+ at both tube anodes, voltage drop across both cathode resistors. Measured, not calculated.
so at idle, you have 275V at the anode of the 6V6, you have about 7v across the cathode resistor, so you have 267V anode to cathode. Yes? If so, your B+ is about 90V ABOVE the RCA manual specs for the bias and load.
Next question is the oscillation...
