anyone recognize this valve?
hello,
it was given to me when I purchased some other valves, I wish to use it but I need to find the specs, rectifier valve I believe, directly heated, no type label but some numbers on the side. any ideas? any help would be great.
cheers,
It is hard to tell by that three numbers, if you can adjust the AC voltage in put,( 100v to 400v) try to connect to pin 4 and 6, 5v DC to pin 2 and 8, load up with a power resister (25w and up 5k in value) from pin 8, center tap of the AC is the ground, use a DC current and volt meter to check the relation between AC in and DC out, then you will know how to use it
regard tony ma
regard tony ma
Pins 6 & 8 might be a challenge!
One other point that may help to determine if this tube is a 80 or a 5Z3 is the height of the top of the tube to the bottom of the pins. A type 80 is built in a ST14 envelope and will be something on the order of 4 1/16" tall. If it is a 5Z3, it will be built in a ST16 envelope and will be more like 5 3/8" tall.
Mickeystan
