Psu h900
Hi..Apex..I'm sorry to ask againt this question...How effect with this supply fo H900??
Pozdrav..
Hi..Apex...my friends ask to me..for PSU H900..Can he used two transformator with seri in secondary tap 57,2v-26,7v-0-0-26,7v-57,2v..0-0 is CT tap.
So, because I no background technic electronica..I hope U will explain to me.
Pozdrav..
Pozdrav..
I will be busy whole summer, sorry for answers, I try to help, but I hope from other people to help begginers also.
ok sir...you really are very busy this summer...goodluck with what you are about to do this summer...
Thank you, I don't want to use forum for advertising or promotion of my business.ok sir...you really are very busy this summer...goodluck with what you are about to do this summer...
I mean that each trafo is 8A with secondary tap 0-26,7v-57,2v. And two trafo with applied seri on secondary tap.That transformers can be used for H900, what is power of transformers? If power is too low it can be used in dual mono configuration or in parallel.
Pozdrav.
we look forward on your site eu.netThank you, I don't want to use forum for advertising or promotion of my business.
thanks for sharing experiences and ideas
You can used transformers as you suggest with 0-0 center tap.I mean that each trafo is 8A with secondary tap 0-26,7v-57,2v. And two trafo with applied seri on secondary tap.
Pozdrav.
Thanks Apex....Now I know that,,,,
Puzdrav
transformer
my friend made that xformer for me...
by that time he made it for a day...
just pm me if you want to...
or send me message to my facebook account
sound_bac@yahoo.com
@ esobie
where did you order your tranformer? how much? how many days work?
sound_bac@yahoo.com
With this supply dual trafo 8A CT-26,7vac-57,2vac, how much power will be product from H900??
Pozdrav,.
500W/4RWith this supply dual trafo 8A CT-26,7vac-57,2vac, how much power will be product from H900??
Pozdrav,.
Pozdrav
power up a bit
Hello Master Tony, Apex, gurus,
As I need to boost up this circuit a bit to 600w at 8 ohms, (as per Apex, this delivers 500w @ 8 ohms), what's the simplest way to modify it?
increase voltage?
add power outputs?
TIA & Regards,
Joel
yes i am....
I install the zobels right at the speaker output terminals, you can use anywhere from 2.2 to 10 ohms....the thing is, carbon comps can be used here and if you are palying your amp loud, you better get several 2 watters in parallel if you want those resistors to last....
increase voltage?
add power outputs?
TIA & Regards,
Joel
Increase rail voltage to 120v-60v-0-60v-120v, and you have 650w at 8 ohms, but 4 ohms will be minimum speaker impedance. With 110v-55v-0-55v-110v rail voltage you can run 3x8ohms (2,7ohms) speakers in parallel per channel.Hello Master Tony, Apex, gurus,
increase voltage?
add power outputs?
TIA & Regards,
Joel
Secondary Voltages
Ok.
So what's the secondary voltages then?
87-45-0-45-87 ?
VA = ?
Thanks.
Ok.
87-45-0-45-87 ?
VA = ?
Thanks.
84-42-0-42-84, 2500VAOk.
87-45-0-45-87 ?
VA = ?
Thanks.
Ok.
87-45-0-45-87 ?
VA = ?
Thanks.
Thanks Mile
- 900W H-class PA Amp with Limiter
