apex,
treble now working
response differ from different application
using guitar input to line treble low response good mid,low
using playback to line mid treble ok low lacking
treble now working
Subwoofer X-over with inputs from line or speakers.
sir,
do you have schema and pcb layout for this project???...
tnx.. regards...
apex,
do you have pre amp specialy designed for instrument
since we have plenty of main amp choices
if we can have diy pre amp for
guitar,(electric)
bass(guitar)
acoustic(guitar)
commercial instrument amp claim that these three have different pre amp stage
that would be fun to built
guitar,(electric)
bass(guitar)
acoustic(guitar)
hi engel dela pena
greetings your e mail address please something nice for u
thanking you
andrew lebon
thanking you
andrew lebon
engel9mcnaly@yahoo.comhi engel dela pena
thanking you
andrew lebon
No, but you can find in post #35 nice guitar amp, and can be use in other instrumental aplication,apex,
guitar,(electric)
bass(guitar)
acoustic(guitar)
apex,
my ml3 on her way
regards
Engel, what did you use for PCB etching, is that a image transfer?Im using the + photo sensitive I got from alexan but I have this ordinary copper board that I want to use and I was thinking of better way to etch this board, thanks bro.Im located here in tanza,cavite.🙂
jhoel4749,
flatbed printer i think is the best
direct pcb printing
check out youtube
you will get the idea,
this might sound very futuristic
paper tape or maskin tape sometimes is the best of all the process i already tried
i also tried silk screen printing,this process is also good
direct pcb printing
check out youtube
jhoel4749,
direct pcb printing
check out youtube
Are you using this method on your pcb? its true it is the best but also sound costly, i need to look for a printer shop that uses this printer. 😀
Subwoofer X-over
Hello Apex,
Where's the "auto" terminal connected to? 😕
I have an AR powered sub, having an auto function that turns on automatically when it sensed a signal and turns off eventually when no signal.
Tnx.
>Joel
Hello Apex,
Tnx.
>Joel
'AUTO' is for auto start function, but but post signal to another pcb with reley.Hello Apex,
Tnx.
>Joel
sir
can we take a look with your 'AUTO CRKT'???...
tnx
Yes, where is the fire 🙂led vu meter board???????? yes or not
wondering mind
i just wonder why this thread suddenly runs out of post???...are you guysnot coming back here???...
aren't you guys interested with sir mile's schemas???...😕😕😕😕😕😕😕😕
Hi apex,
I have attached schematic of tone control_20Hz-20kHz.I want to use 47k pot in place of 10k pot so can you help me to change the RC network value?
thanks
thanks
- Live Sound
- PA Systems
- Mic, Line, EQ... Preamps
