OLD THREAD Salas low voltage shunt regulator (V 1.0)for DAC
Salas low voltage shunt regulator (V 1.0)for DAC or other project!
Hello!
There are many member love the design of Salas and they require a low voltage pcb Salas again
I like most is vesiont 1, because I have used successfully in the DAC-END.
You can use the DAC, like I'm doing, or for other projects.
V 1.0 design by Salas
Information:
There are three sources that: 2 + and 1 -.
From 5V-30V, the current 10-200mA
So I open the group by making PCB design of low voltage Salas.
You can see Salas design in:http://www.diyaudio.com/forums/powe...listic-salas-low-voltage-shunt-regulator.html
And I use for DAC in:
http://www.diyaudio.com/forums/group-buys/155960-dac-end-andrea-ciuffoli-group-buys.html.
DAC End 2 - the AD1865N-K with single ended vacuum output stage
It is cricuit of The simplistic Salas low voltage shunt regulator
PCB Salas low shunt V 1.0
Material: FR4 – 1.6mm
Layers: 2
Board size: 125 x 95 mm
Surface finish: Immersion Gold
Soldermask: Both sides – RED
Silkscreen: Legend on top
The price: Board set
Total: 18$ including ( Shipping by surface mail + fre pay pal = 3$ + one PCB = 15$)
And this layout
Since there is an e-commerce site in Quanghao's signature now, and his board GBs have become a steady venture, there is no logic of group buy essence anymore. There is a vendor forum area being offered by DIYA that the interested parties can ask for. Therefore Quanghao's GB threads are closing. Communicate directly for any outstanding commitments. :cop:
Edit: Quanghao asked and got a Vendor forum of his own, old threads moved here.
Salas Low voltage shunt --is this pcb available?
I visit the website and noted that there is no price for the pcb.
There are 3 outputs for this pcb ? The output voltage depends on ac input voltage or adjustment values on the board ?
Sorry for my ignorance
kp93300
New Design PCb Salas low shunt
There are so many members want me to do this PCB. I find v1.0 very stable Salas low and very low noise. In this PCB you can use for projects ranging from 3 V to use 50v. with 3 outputs including 2 + and an early start - with a maximum response line 250-300ma! you can see by the pictures!
If you like you can show me please!
I hope you can offer this for sale soon.
kp93300
quanghao,
I hope you are not misnderstanding me, I am not asking you to split boards for sale. But for the DIYer to have the option of splitting the boards if needed. I guess I am asking if each section is laid individually. I think it's a good option to have on the boards.
