Greetings everyone,
I just had a pair of end bells blasted to get all the old paint off. The question is should I paint the inside?
Thanks,
Ray
Thanks,
Ray
If you live anywhere where the humidity is high, paint them, otherwise they will rust. Bare steel lasts about 5 minutes in south Florida.
Thanks, my intention was to put the oven on low when the wife is at work and bake after painting. And yes, I had lived in Melbourne for quite a few years and unless it was painted, it rusted!
How's the sweep tube experimentation coming?
I have very little time now since I tend to be at work for most of my awake hours right now. I should get at least 2 days out of the 3 day weekend coming up, so there might be some glowing tube time. I finally got to stick a pair of the 35LR6's that I got at the Dayton hamfest into the red board and crank 250 watts out of a single pair of tubes.
I recently blasted and painted the end bells from some old HP transformers for reuse on some open frame OPT's. I primed them inside and out with flat black RustOleum spray paint, then sprayed the outside with several thin coats of Krylon gloss black. I just left them outside in the sun to dry. They came out very nice.
Do you suggest I prime first? I did buy the rustoleum paint, but didn't give priming a second thought.
In my case I had several cans of paint already from other projects. The Krylon specifically stated to "prime bare metal" on the label, and the Rustoleum said that it could be used on bare and even rusty metal. The rustoleum wasn't shiny, so I used it as a primer, and as the top coat for the laminations.
Definitely use primer.
It is also a good idea to prepare the surface by giving it a good scrubbing with plenty of soap and hot water to de-grease it. Dry well, and then wash it down with acetone. This helps remove any residual grease, and helps remove moisture. Once this is done, don't touch the surface, and prime with the Rustoleum red iron oxide primer (reddish-brown in color). Let dry 24 hours, and don't touch. Then paint with the color of your choice (I use Rustoleum paint for this as well).
This is how I painted the steel chassis's of a couple of projects I did, and haven't had the paint bubble up and peel yet.
I have used that primer as well on a really rusty trailer we use at work and that paint has stuck to it for five years now with no signs of bubbling or flaking.Definitely use primer.
What is the feeling about air dry vs low temp oven dry. My thought since the wife will be at work is to do a low temp oven dry.
Thanks,
Ray
Thanks,
Ray
Yes, clean is important. I used a Scotchbrite pad with water. After dry, wipe down with a lint free cloth and a solvent. I use lacquer thinner or mineral spirits, and work outdoors. Acetone has a lower flash point than gasoline. I saw two incidents of spontaneous trash can fires due to acetone before it was banned from the factory and replaced with some Freon derivative, which has also been banned.
Actually I was going to "clean" the bells with brake cleaner since brake cleaner cannot leave a residue.
That works. I have used carb cleaner too. Both of these will take paint off!
So, not to beat a dead horse....would you prime, wait a few days and then paint?
The primer must be thoroughly dry. In my case that took about 1 hour in the Florida sun. I put down the top coat about 2 hours after the primer. Allow return to room temp before painting, and paint in the shade. Let them air dry in the shade for 1/2 hour or so before "baking".
You might not have the whole backyard a for a drying oven, but if you can smell the primer, it isn't dry yet. A black end bell will be too hot to handle after 10 minutes in the sun here. I painted those end bells in November too. They were still too hot to pick up.
I would assume that 24 hours would be a sufficient wait time even in northern climates. See what it says on the paint can. Many have a minimum temperature spec. It should also have a time between coats. Many new paints have less VOC's so they take longer to dry. The cans that I have are a few years old.
If your paint is old, or has been sitting upright on the store shelf for a long time, the solids are all seperated and sitting in the very bottom of the can. I usually set them upside down a few hours before use, and shake them for several minutes right before use.
Usually your paint cans will have suggested dry times. A lot of the primers I have used say something along the lines of top coat with in two hours or after 48 hours.
I find that brake cleaner leaves an odor behind which implies some sort of residue. I think I probably used isopropyl afterwards since that definitely leaves nothing behind.
Around here it is just as cheap to get them powder coated as it is to buy a decent can of paint.
dave
dave
- Tubes / Valves
- Painting transformer end bells
