This design looks promessing...
Found this on the net. Looks promessing to me.
Years earlier, i had this idea of combining a front and back horns
(for P.A.) similar to what a Altec VOT and Jbl 4530 Frankenspeaked together
would look like.
Building a similar design enclosure with a Fostex Fe208 seems like
a good idea?.
I could not find who created those wonders, would have love to
know more about them.
Would that front horn increase high frequencies too?.
Yeah! it does have a Westminster influence.
I wonder if the high frequencies would be "buried" under mids and
lows...
The Beauhorn Virtuoso also has that midrange horn "thang" goin on.
I suppose the advantage a two way like the Tannoy Westminster has, is the tuneability of both the crossover and the cabinet in the design stage.
I suppose you know that the Westminster is the heir of the Autograph about which I was talking before...it has the advantage of being corner loaded for the bass horn. You need good corners, though...
Good corners let alone good rooms are rare in my present domain...that old adage, High Efficency, Small Size, Good Bass, pick any two ...seems to rear its ugly head.
For those who have done their own research...is there any less complicated construction that has a high degree or return of the "physical reproduction" of the musical event...or is it still true that the last 20% takes 80% of the resources...:rofl:
