Start-Up Delay for tube amp !
Will something like the above posted circuit help to get rid of turn-on thumps in a preamp or line-stage ? Also would it be better to use something like a CL90 type in-rush current limiter ? Basically just trying to understand how such things effect operation at start-up ect....
Here you go: http://www.diyaudio.com/forums/tubes-valves/168981-lets-settle-b-cold-tubes-issue-9.html#post2226032
But first of all you have to find the cause of cracking and popping and solve the main problem. I had similar problem when used some tubes out of specs for max voltage between cathode and filament. I had to select tubes that don't crack and pop.
The only snap crackle or pop I can think of comes from "Rice Crispies" Lets hope you don't sweep them under your rug ! I'm talking about a turn on thump heard through speakers sometimes when first turning on some amps !:flame:
Hi Nigelwright7557 ! I'm kinda new to building tube amps ect... So time back I had built a SOHA tube HP amp, it was a very good sounding though the design had a few flaws. One of them being turn-on thumps, the current revised version takes care of such things ect... They used a relay based delay of some sort ! Its called The Super SE SOHA II and is getting rave reviews ! Its both a HP amp and Line-stage in one.
Unless your amp has turn on thumps I wouldnt add the extra complexity of a soft start.
Having read through DIY audio threads for a number of years now soft starts are always causing problem. If something can go wrong it will eventually go wrong. KISS keep it simple !
At least the soft start doesnt use a relay and a relay is usually the cause of the circuits eventual failure.
I can understand not wanting to apply full mains in one go but the smoothing capacitors will take a little while to charge up slowing down the HT.
I am not quite sure what damage this does to the heaters.
I tend to use DC for my heaters so again I have the benefit of a smothing capacitor charging up to slow thinsg down.
This thyristor relay is harmful
It switches on abruptly
It is opposite to soft start that is actually desired to minimize inrush currents.
Stick a resistor across the SCR to allow a soft start, and the SCR will provide full power when switched on.
The problem with such soft start circuits is that as the tubes start to conduct the circuit is limiting current flow so voltage does not come all the way up till the relay closes any way.
It won't help. Look at schemo: the cap after this delayed relay may be softly charged up to the voltage equal only to rectified voltage minus the sum of all breakdown voltages in a commom Zener string. Then it will initiate it's hard start.
If you really want a soft start, you may go this way: http://www.diyaudio.com/forums/tubes-valves/168981-lets-settle-b-cold-tubes-issue-9.html#post2226032
Does the SCR have a progressive on nature ? If not would a simple CL90 type in-rush current limiter in most cases do the trick ? I'm really not sure what I want, just trying to learn and understand about various soft start techniques used and why ! The diytube ST35 dynakit EL84 amp uses A CL90 also !
