Joined 2002
Hi Airpower,My Hybrid MM/MC phono Preamp, using 3 tubes 6DJ8/6922 and J-fet 2SK170 per channel
What is the purpose of the Fine Gold cap? Are they good caps in your opinion?
Kind regards,
Bas
Holy crap Head, that tube is huge. Where did you find that tube and sockets? Do you have a schematic? I am wondering if I could use this tube instead of the GM70. What do you thinK?
Hi DJN,
That tube IS huge. 15 inches!!!
1 channel weighs about 50lbs
I made the sockets myself, nothing on the net going for this...
They fit well but a lot of work.
It is way bigger than a GM70. The whole thing started because I wanted to build an amp with a GM100 (yes, call me crazy, I'm used to it) couldn't find enough of them nor for a descent price.
I'll post some more pics soon, the second chanel is almost done. STEREO and a rather high electricity bill (over 1kW in)
Here's the schematic and the drawing for the socket.
any more questions, happy to answer.
And by the way, it sounds magnificent!!!
Thanks Head. I did some measuring last night and there is no way those would fit on my existing chassis. I have a lot of old heavy iron laying around here and think I will start collecting for a RS607 amp. Might be a while before I have all the parts but I really like that tube.
My first valve amplifier
Alex .
Wow!
Congratulations!
Professional design.
Alex .
Superb work. Love the PCBs.
Is that a Grommes 260 as listed in the subject of your post?
Did they not use a 6L6 and a 5U4GB as well? I can see only 4 tubes (per channel - 12AU7, 12BH7 and 6550).
....thanks , I have use ECC 82 and russian 6P3S in final stage . Link Gegentakt-Verstärker in AB-Betrieb für EL34 / 6L6GC
Alex
Alex
Alex .
Nice work Alex mm, just change the Faceplate (solid Aluminum) and Solid Knobs you have a perfect project!
Joined 2002
Post schematic and parts used ?
Hi
The schematic diagram can be found here
www.borbelyaudio.com/adobe/15wse.pdf
More info here
http://www.diyaudio.com/forums/tubes-valves/137009-6c33c-b-pp-se-14.html
More info here
Joined 2002
Hi
More info here
I'm just having a hard time tracking down the transformers.
- Tubes / Valves
- Photo Gallery
