Hi guys. I am new at this hobby and have bought from ebay this kit here
LM3886 Hi-End AMP DIY KIT component 68W components NEW - eBay (item 260425032471 end time Jun-03-10 02:06:43 PDT)
Now I consider this transformer here
MULTICOMP|VTX-146-225-118|TRANSFORMER, 225VA, 2 X 18V | Farnell United Kingdom
Do you guys think this should work ok ?
jog
jog
Transformer specs should be far enough for home listening levels.
I meant that in case of using 8 ohm speakers
Now I got my amp up and running. Transformer is 225va with two 25v secondaries. My speakers are 30year old Technics 8ohm. The sound is above my expectations bright and warm. Bass is comfortable and natural. Works very nice on jazz. Next thing is to build a housing for the unit and I must build a preamp for my LP player. Any suggestions regarding a simple preamp?
reg jog
reg jog
reg jog
Are you using MM or MC cartridge? You looking for a kit?
I am using a MM. Looking for a kit or a simple preamp to build from scratch.Are you using MM or MC cartridge? You looking for a kit?
You may consider ESP's phono amp and line amp. Here is the link Hi-Fi RIAA Phono Preamp. The circuit is not complicated that can be implemented on prototyping boards. The components are also very common and inexpensive.
The VSPS on this page is pretty good and straightforward to make for a phono stage:
RJM Audio - DIY Projects
You can probably find a cheap board or kit for it too.
My bad memory.Haven`t used the thing for 20 years.You may consider ESP's phono amp and line amp. Here is the link Hi-Fi RIAA Phono Preamp. The circuit is not complicated that can be implemented on prototyping boards. The components are also very common and inexpensive.
The cartridge is a MC 0.35 mV output.
The cartridge is 20 years old?
- Chip Amps
- lm3886 beginners first project
