First dual driver T-Line Enclosure!
Hi I'm new to the forum. This is my first t-line enclosure I built for my 8" subs😀. Pics here
Rather large gap here :whacko: Hopefully silicone will fix it!
Still need to cut holes for the drivers and glue everything tomorrow...🙄
That gap looks kind of big, if you don't have a table saw you could just work out the lowest point on all your sides and then sand down to that level. I did this with my subs it works but won't give you the most attractive appearance.
They should ideally be butted together, though if using an offset driver positioning, then measure down its inside length from the closed end and mark it off at 0.349x its measured axial length, then locate the drivers equidistant on either side of this mark and space them a bit to allow a ~0.75" square 'rod' brace be glued to the back of the baffle between the drivers. If this pushes them up into/over the first fold, then mount them with the first driver at the closed end next to the terminus.
GM
I mounted the drivers parallel in the middle and sealed everything together. One driver is flipped around because i was told that this reduces cabinet vibration and lowers distortion. The end result is AWESOME BASS!!! Nice clean and low.. Correction, these are actually 6" drivers (measured from screw holes across). Hits hard down to 30 hertz but has a noticible dip at 40-50 hertz though. Are there any fixes for this other than EQ-ing?
Here you go!!! Not the best cuts in the world but it works beautifully!
My first two ported boxes on the left..
Drivers here
Massive port 😱 compared to the old port
Enjoy!!! I might post up a video later..
