New 300B single end
I can listen the sonic features for both Mcap and Jensen capacitors within this 300B amplifier.
Oh-yeah! A 50W resistor, it shouldn't cause any problems, it want neither get warm nor worn... 😀. I measure all cap's I use, whom will carry AF, takes a bit longer to get started, but you'll get it "back" when you're finished the amplifier. 5% tolerance, is very nice for a non-polarized electrolytic cap... And with the 1k resistor the roll off frequency is 1.6Hz.... But I've never used Erse cap, I've spent loads of money on styroflex/polyporpylen(<-- in Swedish), MKP Mundorf MCap, about €40 for a 100µ/100V, typical +/-1.5%. So I'm gonna checkout and try the Erse Cap, since it's much cheaper, and if it sound okay too, then, bye, bye Mcap... 😀 Although I will keep using them(Mcap) in passive filter designs, for speakers, I've tried nearly hundred different brands, but none, has ever come close to Mundorf's Mcap's.
MKP Mundorf MCap, about €40 for a 100µ/100V, typical +/-1.5%? You can try Mcap Ecap Elko bipolar cap for 100uF/100VDC. They are not too expensive. The prices of Erse capacitors are low and are worthy to try.
Have you tried Jensen caps?
Thanks.
Further information. The wires for connection of audio section are Neotech AWG22 UPOCC copper hook-up wires. Neotech is a famous cable manufacturer for audio in Taiwan. UPOCC copper is made by Neotech.
Japanese Noble power switch, Alps 100K carbon film volume potentiometers and UK RS silver plated selector were used in the 300B amp.
Hi anystereo,
I can offer Full Music 300B Deluxe limited edition. The price is US$280/pair.
Thanks,
Tony.
Where can i buy a pair of:
thanks
anystereo
