500W PA amplifier with Limiter
thank you so much...🙂
mje's are nowhere to be found in our city... thats why i settled on using TIP's
but still thinking of H900....🙂 hope Engel de la Pena would tell me where to find MJE's..
i'm located at Iloilo City, an hour of plane flight to Manila
mane go alexan if you go to manila
i'm afraid we cannot build h900
but instead build b500 with tlo72 step driver all parts available
regards
Apex
Logo missing
What about heating, you use only one fan for cooling?
I used HS with dimention 40cm x 7cm x 16cm. In test to drive speaker R-L 4 unit 15", each side 2 speaker 4 ohm with 50% volume...It's PA hot but I still can touch the HS...not so hot...😱. If in operasition PA so hot, I will add fan...Thanks Apex... your LOGO I will write in my box PA 😀
@Eesbiboi..
Thanks..I used cap genuin Philips 2 x 17.000uf/65-100VDC 😉.
http://upload.kapanlagi.com/h/20100601075525_elko_4c045a7d995d8.jpg
