is it right value
hiii ....
I have question about value of capacitor
is a 0.027uf ciramic capacitor and value = 27000p (273)p
is it right??
and what about another capacitor
0.082uf is it (82000) p 823 p
and
0.001uf 102p
and
0.0027uf
0.001uf
etc..
The first one, .027 microfarads is indeed 27000 pF.
The .082 is 82000 pF.
The .001 is 1000 pF.
To convert microfarads to picofarads you use a factor of 1 million, or 10 to the sixth power. These days, many use nanofarads, which uses a factor of 1000. So a .01 microfarad capacitor is 10 nanofarads, or 10000 picofarads. Just move the decimal point the required number of places, using zeros to fill gaps (or removing leading zeros) where appropriate.
thanks alot....
some one say that i need electrolyte capacitor here 0.027uf not ceramic capacitor
i'm still have problem with this diagram ..... only with capacitor
please can you simplify as you can about what i need exactly type of capacitor from A to Z with this diagram and value
thank you
thanks alot....
thank you
You can use available capacitors (represented on a photo in the message №5) in this scheme. 0.0027uF = 272, 0.027uF = 273, 0.082uF = 823, 0.1uF = 104, 0.01uF = 103... At other letters of capacitors marks do not look - this scheme is a low-voltage and does not demand special accuracy of capacity values
