Our second new tube amplifier in May is available now. The circuit is 6SN7 SRPP drive EL34 class A single end. It's a simple EL34 single end circuit with pure class A sound. The output power is 7W. 6CA7 and KT66 are also suitable for this amplifier.
Dimension of the amp: 365W x 320D(inclu. binding posts and knobs) x 200H mm.
Net Weight: 11.8 KG
Can directly replace KT66 onto the amplifier. It is very easy to listen and experience different sound on the power tubes.
Net Weight: 11.8 KG
We now offer a promotional price for this amplifier, USD438 including Russia 6H8C(=6SN7), China Shuguang EL34-B and 5Z3P(=5U4G). The amplifier was designed, made and soldered by Thomas.
The output transformers are made with H10 EI 86 x 40 mm x 0.35mm steel cores. The primary impedance is 3.8K and secondary impedance is 0-4-8 ohms. The output power is 15W.
Side view.
Japanese Matsushita 100uF/100V capacitors (blue caps) for the cathodes of 6SN7 and EL34 are used in this amp.
- More Vendors...
- Twin Audio
- New EL34/6CA7/KT66 integrated amplifier
