What type of integrated amp is this please.
frugal-phile™
Joined 2001
From looking at it from my inexperience, I don't recognize a transistor output section or heat-sinks
Output devices hi-lited. Chassis is the heat-sink
dave
[FONT=Arial, Helvetica, sans-serif]Thanks to all for drawing those sections for me, such excellent help on this site!
I'm going to do some more search on this unit, but so far it is stated to put out:
50 watts at 8 ohms and
[FONT=Arial, Helvetica, sans-serif]90 watts at 4 ohms using Class Alpha Amplification.
Is Class Alpha similar to or the same as Class A?
It would seem a rather small heat sink assembly for Class A...no?
Also, this unit is five years old and spent its life on the east coast of Florida - although in an air conditioned home. Is this a possible issue with the components?
[/FONT]
[/FONT]
can be an issue ...but looking at the all set up size of trafo cooling facilities it doesnt look like real Class A equipment ...
it is probably a normal class AB amplifier only instead of 30-50ma that is the normal bias for a comercial amplifier this one is probably biased at 120-300 ma to come closer to class A but not pure class A
that doesnt mean that this a bad amplifier on the contrary it can be a very nice amp ...looking ata the quality of material and the quality of built i think that is a superb piece of equipment
regards sakis
Administrator
Joined 2007
50 watts in pure Class A would require a much much larger heatsink and PSU.
It's probably some "marketing speak" for a sliding bias class ab or something like that.
Amplifier classes are well defined... either it is or it isn't :)
Just out of interest what are the device numbers on the output transistors ?
I don't know what the device numbers for output transistors are. I might be able to find out and will reply.
Yes, the transistors have been masked. I don't have a clue as to acquiring schematics... perhaps someone here may. I am interested in this unit as a purchase, but just discovered that a newer model released about 4 years ago offering dual transformers. Some people here as well, other sites have expressed their believes about the disadvantages of dual. Care to offer any comments?
Administrator
Joined 2007
Dual vs single... impossible to say.
It's how it's implemented that counts. There is plenty of scope for messing both up with poor ideas about layout and wiring/grounding etc. More chance of mechanical hum too with dual.
There's for and against and followers of each type :)
So... if it is possible to state that both implementations can be discussed, it is also possible to state that one is better, or that the redesigning of either would be best, or that another - as yet unknown. What, if any, possible theories have been brought forth or experimented with that is not yet realized within known analog audio electronics? I'm asking here because I assume that some or many may have heard about new theories in building and designing the type of equipment on this forum. I'd like to mention Tesla, as an example of the type of thinking needed. Are there any people who are proposing this kind of energy and thought towards audio electronics?
