Driving an experimental transducer with an F5 and driving the F5 with an iTouch. I think the iTouch has a maximum out put of 2V or so, which doesn't give me all that much volume.
So, what input voltage is needed to drive the F5 to full-tilt boogey mode?
Is this right ?
I ran a 1000Hz 0dB test signal from a Denon test cd
and measured the F5 output, using a Fluke 8060A true rms meter,
into a 4Ohm power resistor.
The meter reading was 10v4.
So, 10v4 / 4R = 2A6 , 10.4 * 2.6 = 27.04 Watts rms
10v4 rms = 14v7 peak (10v4 * 1.414)
14v7 / 4R = 3A675 , 14v7 * 3A675 = 54 Watts peak
That jibes with what the F5 should output with 24 volt rails.
Does all that look right?
So, I measured the voltage at the input (101k ) and the meter
reading was 0v57 ? But, if the voltage output is 10v4 and the amp
gain is 6 then the input should have measured 1v733 ? 😕
I'm I measuring the input voltage correctly? What's missing.
The F5 can output more when it crosses into AB. Your numbers are OK but really don't tell you anything about the Class A power or sensitivity.
Best, Bill
Best, Bill
Best, Bill
Thanks for the reply.
Any comment on
[So, I measured the voltage at the input (101k ) and the meter
gain is 6 then the input should have measured 1v733 ?]
Don't understand why I got an input voltage measurement of only 0v57,
the source is an Twisted Pair Sabre32 dac which I believe should have
an output of 2v0 when it has a 0dB signal off a cd. That would be close
to what the back calculation of the F5s output (10v4) divided by its gain (6).
Again, thanks for your reply above 🙂 and I'm not expecting to be tutored.
Check the input and output at the same time. Make sure that you have 0.57 RMS in when you have 10.4 RMS out.
Check the gain setting resistors in your F5. (Refer to Firstwatt service literature). The overall gain is 6, which seems to be set by R1 and (the parallel combination of) R5//R7. (And obviously matched by R2, R8//R6). I think it is actually defined as 1 + [ (R5//R7) / R1 ]
J.
J.
Make sure your meter reads correctly when trying to measure two absolute voltages that are quite different from each other.
If you expect the amplifier to have a gain of 6times then fit a divide by 6 attenuator at the F5 input.
Now measure the voltage at the input of the attenuator and the voltage at the output of the F5. Do not convert anything to average power.
Adjust the attenuator until the input voltage exactly equals the output voltage.
Now, find out what attenuation the switched attenuator was set to. That should exactly equal the gain and the voltage inaccuracy of your meter has no effect on the measured gain.
That's one of the uses for my homebuilt 0dB to -61dB attenuator in steps of 0.05dB
The steps are -20, -20, -10, -5, -2, -2, -1, -0.5, -0.2, -0.2, -0.1, -0.05.
Twelve switches for 1220 steps. Not expensive to buy in the bits.
Or...
If you expect the amplifier to have a gain of 6 times then fit an attenuator at the F5 output.
Now measure the voltage at the input of the F5 and the voltage at the output of the attenuator. (Do not convert anything to average power).
Adjust the attenuator until the output voltage of the attenuator exactly equals the F5 input voltage.
Hi,I ran a 1000Hz 0dB test signal from a Denon test cd
I do the same:
0 db Cd output 2,15V
2,12V at the input R10 (100k)
12,3v at output into a 5,1ohm resistor
i think your 0,57V measured is not correct
AndrewT, my mind boggles! "That's one of the uses for my homebuilt 0dB to -61dB attenuator in steps of 0.05dB" Wow, perhaps I can do this with a pot and do the calc. to a rough estimate. 😛
carlomar Yes, I think the 0,57V measured is not correct also. But, why I'm not sure.
Jen-B Check the input and output at the same time. Make sure that you have 0.57RMS in when you have 10.4 RMS out.
Thought I did, but I will try again.
Spent my free time today revisiting tubes & vynil. Next couple of days are already filled. I know I'm making excuses, but you know reality some times intrudes. Darn. 😡
And, thanks to all for the help.🙂 Will report back, soon I hope. This all came about because I wanted to know if the TP ESS dac was pushing the F5 to its max output when the control was full up with a 0dB signal.
when using a pot to trim the input voltage, remeber when it is in circuit it is loaded by the source and by the receiver.
When you measure the pot, it will probably have no source loading and the multimeter is a load/receiver. You must calculate the effects of these differing loadings.
- What input voltage produces maximum output with the F5?
