Hello all,
I'm using my Aleph P1.7 right now single-ended with a 10K 41-step 1,5dB-per-step series attenuator on the output from Acoustic Dimension. Would it be possible to use this attenuator in a balanced series-shunt attenuator like shown on the right side in this picture:
Ok, I have three questions regarding this setup:
Any drawbacks in this configuration? Is the Aleph P1.7 up to this config? And lastly what should be the value of the series resistors?
Thanks!
Thanks!
It should work OK, I would try 1k for starters.
Just for learning purposes: what is the reasoning behind 1k?
BTW, can I still use it SE when configured in the balanced shunt way?
That's a good question. Referencing the signal to ground, it would surely change the response. After thinking a minute, no, it wouldnt work correctly single ended. A simple DPDT switch would work though, switching the bottom of the att. from ground to the other output.
1K is just a guess as you are using it as a variable voltage divider.
I see that the D1 also uses such a volume control, but there it is squeezed between active circuitry. So that would be the condition for both the functioning of SE and balanced without a switch?
balanced attenuator
If you go to Erno Borbely's web site you will find a tweak for a balanced volume control that looks very similiar to yours that he recommends for use with his equipment. You can compare the resistors used in the balanced arrangement. I have tried it and it works fine. dave
Go to Uskok_Preamplifier. There you'll find exellent balanced attenuator. Some text is Croatian, but drawings are in English.
This site: Shunt Pot Volume Control - World-Designs-Forum shows how to calculate values for shunt controls.
Sean
Sean
- Aleph P with balanced shunt attenuator
