After a lot of searching and not quite finding, I'll try a new thread...
I'll be running a Lynx AES16 sound card running digital XO and DRC in my 'puter, and outputting 96/24 balanced AES/EBU signal to a total of five stereo DACs. Three of these (fronts) will be as high end as I can get them, while the other two (center/surround) will be so-so. I've got a total of five DIR9001s, three SRC4192s, three SRC4392s and five PCM1794As to play with.
So, first question: Chip configuration. I'm planning on a simple DIR9001 -> PCM1794A with clock recovery for the so-so DACs, without any SRC. The "good" ones are the headache - do I go DIR9001 or SRC4392, and if I go for the DIR9001, do I really need an SRC4192 after it? And without any SRC, will the recovered clock from the DIR9001 be good enough? I doubt it, but it would make things easier... As all DACs will only be run at 96/24 from the Lynx there's only one format to worry about, and it's pretty clean. It can run from an external high-end clock, too.
Next: Balanced AES/EBU input circuit. The SRC4392 has a balanced input, making it simpler on that part, but it requires an extra 1.8V supply. The DIR9001 only has single ended input, and needs some kind of circuit for the interface. All Lynx outputs are already transformer coupled.
There's gonna pop up a lot more, but let's leave it at that for now ;-)
Aren't you doing the upsampling in the PC software? I am not familiar with Lynx software and capabilities, but I guess you can have 96kHz from any source. The 96kHz samplingrate gives better TDH+N and channel separation on those DAC's. And DAC's are doing upsampling to the same final value.
Jitter on SRC output is 200ps and on DIR output is 50ps (I doubt that your card is worse). In this way, the SRC would be useless... and I will go for DIR->PCM on all of them.
I'm using software 96/24 upsampling (or in rare cases downsampling) as the first filter on the source, outputting to room correction filters before it goes to FIR crossovers. So the AES16 just takes the processed 96/24 signal and sends it right through. It doesn't support 192/24 without using doube channels, but hey - how much difference does it really make?
I'll go for my original idea then, with DIR to PCM, so the only challenges now is to create the summing circuit for AES/EBU in and distribute a good master clock to three PCMs. Still don't like the idea of taking a recovered master clock from the DIR to drive the PCM on the high end channels.
D'oh! I dove deeper into the datasheets and found out that the only way to connect the DAC directly to the DIR is to use the recovered clock from DIR as master clock for the DAC. The master clock on the DIR does essentially nothing (it will only output audio based on recovered clock anyways) and the DAC has to be in sync with the DIR do to any good. So the only way to be able to use a proper clock I need to put an SRC in the mix. And as far as I can see, a DIR9001 + SRC4192 would be better than a single SRC4392.
Any experiences to share?
I know the Lynx clock is decent, but when has decent ever been good enough for us The best thing is always to have a "perfect" clock at the source, then there would be no need for ASRC at all. Being a pro tool, the Lynx has external word clock input too. I'll check into how that works and see if I can run it from a better clock.
Both DIR and SRC attenuates jitter, but in different ways. The DIR recovers a master clock from the S/PDIF stream with a PLL (Phase Locked Loop) that will "spread out" the effect of incoming jitter, while the ASRC uses a separate master clock as a stable basis for some heavy interpolation and decimation filters.
I spent the better part of last night reading a thread about ASRC by "werewolf", co-founder of Silicon Labs with a masters from MIT and ten years of experience from Crystal, so I've finally gotten a pretty good idea of how the whole thing works. I recommend everyone with an interest in this (which is probably everyone in here, except tube guys to skim through it.
That still leaves me with S/PDIF input circuit and power supply scheme to worry about...
Ive had an AES16. There are way better solutions now.
https://www.xmos.com/products/development-kits/usbaudio2
Wordclock: no luck with this one, you need a DAC that has wordclock output, so it can act as master, and lynx becomes the slave, the lynx PLL is following the DAC clock.
Sounds good, but theres no such DAC. One is UA2192 , has ADC builtin, plus it has its own serious PLL/clock generation solution , and expensive as hell.
DIY solution would be SRC4392, disabling ASRC block, using 'clock out. Too much to mess around with. I2s is simpler.
USB+i2s might need LVDS rx / tx for usable cable lengths. Thats cool, jitter is kept very low for anything but 1bit.
Have a look at the clock frequencies on your Lynx. Mine has one clock with over 450 ppm out!! This is why synchrolock does not work and why they recommend you don't use it.
There are better cards around and pre-upsampling using good software sounds better. HDDs are cheap and sata connection particularly easy and fast.
After a whole lot of ifs, ands and buts I've settled on DIR9001 -> SRC4192 -> PCM1794, but I'll make a couple of test boards with the option to exclude the SRC. Next up is power supplies and implementation, which another user has started a thread on here.
I've done the DIR9001 -> SRC4192 -> PCM1794 thing. It's a good sounding combination IMO. Can't offer anything other than a very subjective opinion on it though.
@tritosine: That USB solution doesn't look bad, but pricey for 12+ channels... And I'm on a pretty tight budget with all the expensive things already bought, so I'm probably gonna have to stick with the Lynx. Still not totally ruling out a different solution. Can always find some sucker to buy the Lynx ;-)
Hijacking word clock from SRC4392 or 4192 is definitely an option, or simply make a discrete word clock divider from master clock. It'll be harder to change sampling rate later, though.
I've looked into LVDS earlier, but again, that means replacing the Lynx with another piece of expensive hardware. Or possibly modding it to bypass I2S-S/PDIF conversion if it's done in hardware.
@fmak: Are you getting 450 ps from a Lynx output, or from another input? I don't have a scope, so I can't check my outputs. Should probably get one...
I'll only be using the Lynx as a source. As I mentioned, I will do software upsamling before DRC and crossover filters. The Lynx will do nothing except push an already processed 96/24 signal, and the SRC is only there for reclocking a possibly jittery recovered clock.
BTW I'm running a dedicated file server with 8 1TB disks in RAID-5 on an Adaptec 31605 controller, so I'm set on that department ;-)
@theAnonymous1: I've read your MicroDAC thread a couple of times already. Love it!
- Digital Line Level
- Multi-DAC: Lynx AES16 -> DIR9001/SRC4392 (-> SRC4192) -> PCM1794A
