Help with tube stereo build
I want to build a tube stereo amplifier. I'm done with waiting around for somebody to sell one here in town in the classified ad, and the thrift stores never has any. EBay has tons but they are super expensive and the shipping charge is a beast.
I want to build one for myself. Can anybody help me with an appropriate design? I would like to use it to drive the audio signal from a bunch of goodies, like my Xbox 360, computer, CD player, TV/VCR. I won't be using a record player with this, ever.
I'd like it to have RCA inputs with a selector knob for it. Speaker wire jacks for speakers, two channels A/B. A headphone jack for headphones with a switch. A nice analog volume control with Bass/treble controls.
It will be open on the top to show off the glowing tubes and chassis. The chassis can be aluminum I've seen other tube stereo designs and they have only two tubes plus the rectifier tube for the power supply. This tube stereo amp is going to be a special thing I will have for a long time, I want bunch tubes in the design so it sounds really awesome and looks as good as it sounds. Also it will be grounded and have a fuse in there and anywhere else it needs it.
My hope is to build this bad boy for under $200. Thanks.
Not. Gonna. Happen.
Unless your prepared to drop most of the frills I have to agree with Miles.
Have you considered a very basic kit like the k502 and add the frills later.
How about a donor amp, faulty amps can be had quite cheaply on Ebay and can be rewired according to some of the excellent designs worked out on this forum
Good luck 😀
I built a little 2-tube guitar amp a little while ago. The only expensive bit I allowed myself was the Jensen speaker.
I like it, but it's in an unpainted MDF cab without even a carrying handle. The cost of the chassis, parts, shipping, basic cutting of the MDF and excluding the spring reverb, was 120% of the retail cost of an entry-level Fender tube amp with digital effects front end. That's without labour, and I didn't have to buy tools, hook-up wire and other consumables such as solder only because I'd bought them already.
One of the good things about desire is that it makes you raise your sights. If you really want what you've described, then realistically you're gonna need some more money. Therefore you will have to earn it, helping us all out of the recession. (Yes, that much...)
Photograph everything you've got including the chassis IN USEABLE QUALITY and post the photos.
w
I think you could build a very simple SE amplifier using a pair of Edcor transformers, a small Allied power transformer (The one George/Tubelab recommends) a pair of 6P14P or 6BQ5 and a 6DJ8 driver on an inexpensive aluminum chassis for about the amount of money you propose. No tube rectifier, and no boutique parts whatsoever, however everything you would need is readily and cheaply available from Mouser, Digikey, Edcor, and Allied. The specified iron would eat about $60 - $80 of your budget, leaving plenty for the rest. (Which could include a decent volume control pot, source selector and a couple of inputs, generic binding posts on the outputs.)
The bigger question is do you have the required skills to assemble and debug something like this, and can you live with just a couple of watts of SE power?
Also I think you need to think simple - forgo the tone controls, and a lot of tubes. Your budget will not allow for a fancy high end amp, but you can put together something nice looking and good sounding if you are very careful. Put the most money in the output transformers as this will determine the end result.
Hamfests and eBay are a good source of parts. Ebay for jacks, switches, fuse holders, binding posts, sockets, wire and the like. Hamfests for tube sockets, resistors, and other passive parts, not to mention tools. Get your caps from Digikey or Mouser.
If you can spend more money over time buy one of Tube Lab's Simple SE amps.
I think a simple single-ended EL84 or even EL34 amp should be do-able for that kind of money! You can get quite creative on it...
Thoughts:
1) What is the chassis that you have already, and what is the lineup of tubes was it powering? eg. 5U4, 6L6, etc. Do you have a pic? Also did you keep the old tubes as they rarely go bad; the older ones are pretty rugged actually.
2) Old computer gear (switches, routers, modems etc) can be a good source for a compact high-quality metal chassis. Failing that, a simple wooden box of some kind with a metal top plate is fine. A wine bottle gift box or jewellery box could work nicely.
3) Output transformers- you are best to get good ones as it really is what makes or breaks an amp. Generally the heavier the better. You can get second hand vintage ones for next to nothing off that well-known auction site, just watch the specs are right for what you are building (PP and SE are not interchangeable!) also watch shipping costs. I have seen full transformer sets (power plus choke plus outputs) go dirt cheap. Oh to be closer to Nth America, costs a fortune to ship anything like that down here to the south Pacific.
4) If you want a source of cheap RCA jacks and other bits, see if you can scrounge a dead 1970s/1980s hi-fi amp, before they went to digital control circuitry. Heck see if you can scrounge a broken tube amp, tube reel to reel or large tube radio- lots of useful bits.
5) An input selector switch and headphone jack could easily be rigged up- you might have to see what impedance your phones are though and mess around to get it right. Or buy a separate preamp and build a tube power amp only.
6) You could do a bit of reading- here is a start that got me into it!
Boozhound Laboratories
Déjà vu. You don't do flashlights by any chance...
No, never saw that site before.
...or is there something else which moved us both?
Definitely something else. The OP was asking way too much for way too little.
I did a stereo VT amp that fits that description quite well, but I sure didn't keep it under $200 despite being able to use the power xfmr from an old color TV, and a few other junk box pickin's (main PS ripple chokes, some Octal VT sockets, a fuse holder, some PS capacitors).
You might be able to make a decent solid state project for under $200, but it would be very difficult to do so with hollow state, even if you had all the equipment to wind your own OPTs since lams and "magnet wire" aren't exactly cheap either.
CP,
An important issue is the speakers you intend to use. Low power SE amps in the $200 price range are going to need 99 dB. sensitive single driver stuff.
Increase the budget somewhat and you can get 12 quite decent WPC from a UL mode "El Cheapo", which will work with 92 dB. sensitive speakers. A full set of power "iron" from Allied costs $64.28, plus shipping. A pair of Edcor CXPP25-6-7.6K O/P trafos costs $94.26, plus shipping. Jim McShane will sell you a kit of parts to which you add a chassis.
Rh84 se
I'm convinced you can build a small tube amp for less than 200 bucks.
RH 84 - Tube Audio ...... RH DESIGN
Scrounge or make your own chassis, use an Allied tube power transformer and Edcor outputs, or do an eBay search for "tube output transformers" and there are always many people selling transformers for SE EL84 amps scrounged from consoles for dirt cheap.
You should get around five watts and come in way below two hundred bucks with console iron even if you splurge and get a 716P orange drop coupling cap and a Radiodaze RDC-100 choke:
http://www.radiodaze.com/catalog-306-page59-60.pdf
You'll likely have to use a solid state rectifier for the power supply instead of the tube one as shown. If you want a tube rectifier you could use a couple of super cheap damper diodes as the 12V filament versions are often available for less than a buck.
As others have said, you will need efficient speakers. Even if you use new iron you should be able to stay below 200 with a scrounged or scratch built chassis.
