using RG6QS cable for subwoofer line in
I have my speakers and TV on an adjacent wall to my electronics with a hallway in between. This has forced me to run wires in wall to hook everything up. Over the years my system has changed and I'm faced with a situation of either using RG6QS to hook up a sub through its line level inputs or using the speaker level inputs of the sub(with speaker wire, of course). My understanding is that a line level connection will be better quality. I use my system almost exclusively for music. I'd appreciate anyone's thought and experience on this
Many would say that a line level input to a powered sub is better than a speaker level input.
But a speaker level input does not need to be shielded.
If you are buying co-ax cable to be run to a sub-woofer, RG6QS (quad shield) is a poor choice.
RG6QS is designed for cable & satellite TV signals.
But RG6QS will work if it's already installed.
Which are significantly wider in bandwidth than our lowly audio stuff...
And optimized for a significantly higher frequency band.
Quad Shield is best in a frequency band from about 50MHz to maybe 1 or 2 GHz.
Quad Shield is less desirable and both analog and digital audio frequencies.
It also depends on how you define bandwidth!
Can you elaborate on that?
I've used it for feedline for HF radio use for a time (1.8-30MHz), while there was an impedance mismatch from being 75 ohms, it did have lower loss than RG-8X. Perfectly acceptable for under 50MHz, provided the run was under 75 feet or so.
Because Quad Shield is designed for a frequency band from about 50MHz to maybe 1 or 2 GHz, the shield works best when the interference is in this range. They trade off low frequency shielding for high frequency shielding. They also chose a center conductor and insulation that work best at high frequency while keeping the cost low.
A Belden paper on co-ax. Just ignore the big word acronyms:
http://www.belden.com/pdfs/Techpprs/CoaxialCablesandApplications.pdf
