An ethernal phenomenon named: "fantasies"
So, as I see, Audium Semiconductors (now NXT) abandonned their 20 times more efficient fancy 100 W audio amplifier and started to explore perpetuum mobile or how to obtain 25W from 5V / 100mA (0,5W - USB2.0) or from 5V / 900mA (4,5W - USB3.0)!
_________________________________________
Erare humaum est! Every one knows this one! But just few knows that this proverb does not end here. The continuation is: Persevere erare, diabolicum!
And your view of the underlying theory?
Hello Zola
The few posts you have made to date seem to be in general cynical snipes. There is no mention in that video of USB that I saw. Leaving aside marketing hype, as an expert of 20 years standing in the field your view of the theory of the solution would be interesting I am sure....
Hello Zola
A little more detail:
"Audium’s IP exploits the high peak-to-average-power ratio inherent in an audio signal. An audio amplifier rarely operates at full output power due to the characteristics of an audio signal, together with the dynamic range of a volume control. The company’s technology ultra efficiently amplifies the signal over the entire operating output power range. The system architecture includes techniques to minimize both fixed losses and output-dependant variable losses, and the modulation schemes use low switching rates to minimize switching losses. Power rail switching means that the amplifiers operate efficiently from a low voltage rail most of the time, with a DC-DC boost converter being switched into circuit to drive higher voltage transistors on extreme audio peaks. Existing audio power amplifiers, such as Class D, only achieve optimum efficiency at or near full output power. Audium, therefore, provide a significant power saving advantage."
That's because it's mentioned on the main Audium web page, not the video.
Last but not least, why do you (and many others) constantly keep comparing this amplifier with D class amplifiers? According to the poor explanation they gave, it is absolutely not a D class amplifier! If you want to classify it, it is more likely a modified BASH amplifier. And BASH has much less problems with idle consumption!
Do BASH amplifiers require an output filter?
theAnonymous1
Thanks for explaining that reference; this link gives even greater depth of understanding about how the AS1001 seems to work and what the company was trying to achieve. What is your view?
Audium digital audio power amplifier side-steps low efficiency problem - 05/10/2009 - Electronics Weekly
What is your view?
I don't have one. I'm just a curious ignoramus.
tA1
Glib ... very glib! ;-)
Sorry, I just meant I'm not informed enough to have an opinion.
One need not be an astronomer to appreciate the night sky. 😉
Well, nearly 200 people have checked this thread today and I guessd quite a few of those looked at the video link I posted.... For such a revolutionary piece of technology and given the demonstration and extra information I have posted I am really surprised that apart form Zola and tA1 (hope you don't mind but the full monty is a lil long!) none of these lurkers have expressed an opinion! Especially as there were so many nay-sayers earlier in the thread ....
.. at near idle. And besides, all these rail switching and fancier modulation class D schemes have been seriously explored decades ago and none of them sound as good as regular old straight PWM. Look for AES papers on it. If there were a decent way to get 20 TIMES more efficiency out of an audio amplifier I'm absolutely certain Texas Instruments and Analog devices, etc., would be doing it already. These guys are either on crack or hoping everyone else is.
>> Andrew Eckhardt
.. at near idle.... uh... no .. at usual listening levels ... thats the point
And besides, all these rail switching and fancier modulation class D schemes have been seriously explored decades ago and none of them sound as good as regular old straight PWM. Look for AES papers on it. If there was a decent way to get 20 TIMES more efficiency out of an audio amplifier I'm absolutely certain Texas Instruments and Analog devices, etc., would be doing it already. These guys are either on crack or hoping everyone else is.
...so there are no new ideas then ... ?? ;-) Cos big capital has thought of them all??
Don't worry, the sound quality of the amplifier will be masked by the horrid scream of the NXT BMR's they will be coupled with.
They do qualify their goals, "We are not targeting Hi-Fi or professional audio, we believe our audio is in line with consumer requirements, our target is 1% distortion or less." I have had similar problems with DC switching regulators, i.e. getting decent efficiency at very low power out. They must see a niche in very long battery life, I don't see the USB application being that interesting. If you needed a couple of seconds of sustained output this and regular class D are on par and you are limited by the USB supply in the end.
What they're doing must be similar to adding rail switching to something like an SSM2319. It would be very efficient but no good for anything but cellphones and bullhorns.
It's not that it is expensive to come up with a different way to turn something on or off, there just aren't that many (that have acceptable fidelity).
Boy, if I had a product that could capture even 10% of the market for amplification in cell phones would I be a happy man ....
So no possibility of ones that haven't already been thought of then ...
Not much at all. But they are very likely to capture 5% of the market by people that believe they are dealing with a significantly superior product.
Anonymus1, I didn't say It's a Bash amplifier. I said that "it is more likely a modified BASH amplifier" than a class D amplifier. Look at these output filters, do they look to you as filters for a 100W amplifier in class D? Anyway, we just may assume how this amplifier works, no dataseheets, neither any explanation from the manufacturer! Does it seems to you a little bit weird that we have to assume something in a so precise science as electronics is?
- Class D
- Audiom | 100-W audio amp is 20 times more efficient than Class D chips
