Tube Sockets for oddball miniatures
I'm trying to come up with PCB mount tube socket for a Russian IV-12 VFD tube.
It's a 10-pin miniature, in the same circle as a 9-pin miniature (12mm pin dia.) but with closer pin spacing (32.7 degrees vs 36 degrees) :hypno2:
I tried some Mill-Max PCB pin receptacles. Best is 0312 but non-stocked and $0.89 per pin = $8.90 a socket. The 0314 is great but the collar shorts to adjacent pins. Not sure who else makes receptacles.
Someone else ripped pins out of cheapo plastic 9 pin sockets and used them.
Any ideas?
Any ideas?
I use the sockets out of D25 female connectors and use this :
Valve & Nixie Socket Calculator
to calculate the positions of the PCB pads when I make a Protel footprint
for the component.
M
Thanks, I checked again and I had the wrong dimensions in my original post.
No luck finding PCB mount 10-pin miniature sockets. There are at least three Euro types: B10A, B10B, B10C, 10C12 bases, so it is confusing.
The Decal B10C base - 10 pin, 1.02mm (0.040") dia. pins, 11.9mm (0.469"), 34° pin spacing, gap 54° - matches the IV-12, 6X9, ECF200, PCF200 etc. It's similar to Russian РШ23 (RSH23) or the B9A 9-pin base.
There are some ceramic solder lug ones from China on Ebay, but no PCB mount.
I found Euro tube socket info here:
Pentodensockel - Pentode Bases
for the component.
M
That's a great idea! I'd thought D-sub pins are smaller than tube pins (1mm/0.040") but looking again, I find they're the same size. What part are you using? I found solder-cup ends which I assume you press thru your PC board. HDP-20 series AMPLIMITE D-Sub Connectors (AMP 66569-3) looked okay with about 0.075" PCB holes.
Otherwise, it's the (expensive) machined contact pins Mill-Max 0314 or Keystone micro-jack #1414 would work for tube sockets.
