Need source for T83511D212-05 relay brand is potter & brumfield dimensions 20mm total length. Type dpdt, 5volt 2amp @25v.. Any suitable cross for another brand would be fine. I can't find source anywhere for this. Any help would be appreciated. Pic is attached.
If you know the pin spacing then it shouldn't be hard to find a replacement that will work.
It's a standard 5V DPDT relay. Something like this......
Digi-Key - PB1121-ND (Manufacturer - C93416)
Wow,I was beginning to give up hope on finding it.This appears to be exact relay-same spacing & everything.. The strange thing about this is I sent this same pic to digikey customer service & they reported back they couldn't cross ref it. I really appreciate this-you saved me alot of time. Donald
Well, they're not going to recommend a substitute part if they don't have an official cross reference for it (even if they have 100 other suitable parts).
If they did that and the relay was part of a critical application, then that could leave them open for liability if the part failed and caused some catastrophe.
