No bass in 300b amp
I'm using Polk Monitor 50's (quoted sensitivity 89dB), o/p transformer Hammond 1627SEA.
Hope that's specific enough 🙂
I use those same speakers connected to a Yamaha digital piano and powered with and Audio Source AMP100. This is not for music reproduction, in this case it is a musical instrument used for practise.
The AMP100 does 50 WPC into 8ohm and with the M50 speakers I need to turn the volume control all the way up. But the bass is quite good. Because the system is conected to a piano I know exactly what frequenccies I send, (middle C is aboutr 260Hz, the next C down is 130Hz and so on.) the speaker does 50Hz no problem but I sit on the piano bench only 3 feet from the speaker and the volume on a 50W amp is at "10".
For music reproduction in a decent sized room I'd recommend about 100WPC for those speakers unless you like to play at low lovels then 50WPC is OK.
I suspect your amp is very much under-powered for those speakers. If they are spec'd for 89 dB then that is likely measured at 1KHz or something like that.
A better way to test the amp is to get an 8 ohm dummy load and measure the AC voltage across the load while sweeping a test signal in the amp's input.
I used to own a pair of those (back in my HT days)...and I am pretty sure that a minimum of 20 watts is required...I think the range was about 20-150?
I am not sure what the output on that particular amp is, but before you start making major changes and If you have the ability to, try some more efficient speakers - maybe a pair of full rangers.
I am currently running a little spud amp (6T9 tubes at about 1.5-2 watts) with some fostek FE103E's (efficient to about 98db) that puts out a sweet sound and is very "room filling".
Paul Joppa's 102 dB. rule tells us the minimum efficiency to use with the 8 WPC SE 300Bs yield is 93 dB. Clearly, the general lack of listening volume is directly related to insufficient power O/P.
I suspect the poor bass performance is related to 3 factors. The damping factor of a no NFB SET amp is inadequate to control the woofers in that MTM speaker design. The 2nd factor is the comparatively low primary inductance/impedance of the 1627SEA O/P trafos. IMO, the 1630SEA would have been a better choice. The 3rd factor is the bass extension of the speakers themselves, which is 3 dB. down at 57 Hz.
While little can be done about the O/P power level, a quick experiment is available to test the damping factor idea. Connect those nominal 8 Ω speakers to the 4 Ω taps.
On top of the reasons Eli mentioned, the ear's sensitivity for extreme frequencies (bass and trebles) is low when the listening volume is low. It's hard to make a good assessment of the amount of bass the amp is delivering, when it plays too quietly.
I'm afraid your speakers might not be the ideal ones for a low wattage SE amp. Or maybe the amp is not driven to its maximal sensitivity?
Kenneth
