Kevin,
I agree. I wanted to give the amp the capability to handle both kinds of cartridges, but since I'll only be using one (primarily MC) i'll use a jumper or something internally to switch them. I'll still be using relays for switching the impedance of the input.
I did read something interesting about latching relays. Does this mean I can use a momentarily closed switch on the coil to switch between the positions (using a DPDT relay?) so there will be no current flow in the relay except for when the positions are switched? Am I understanding this correctly?
Joe
Joe
Kevin,
<snip>
Joe
Yes, exactly.. Note that latching relays have their own setting of mechanical issues, and many are not suitable for use in very low signal level circuits - so choose carefully.
