I don't believe cables make a difference, any input?
As someone who uses the shortest IC possible on my monitors I can actually say that I don't think that logic is exactly correct. It will depend on the specific situation most likely and if the excess cable ends up being coiled or not. But with cables that aren't the same length you can possibly get a non symmetrical stereo image. With surround sound where the speakers are all a different distance from the source this is something that should be considered.
The power loss in speaker cable or any non coaxial transmission line is (I^2*R), current squared time resistance. Whether speaker cable loss is noticeable depends largely on the power level through the cables. Is it important if one cable is 4 feet and the other is two feet, not really. But if we are talking about 50 or 100 feet then yes it is significant and cable lengths should be equalized.
Some manufactures of speaker cable will boast of independent strands to reduce skin effect. This is bull because skin effect doesn't occur until radio frequency is reached and becomes increasingly more significant with an increase in frequency.
At the low end of the RF bandwidth it's not even a concern at all.
An 8 ohm speaker may have a DCR of around 6 ohm not including the complex impedance of the speaker. The DCR of a speaker is effectively in series with the speaker so your amplifier is always, seeing at least the DCR. This may very only by the crossover network in the speaker and number of speakers in the system. So at what cable resistance does the loss become significant?
Speaker cable follows the same electrical physics that any other wire does.
95% of all said about high end speaker cable is just marketing.
Do the math and make sound decisions.
This argument also applies to damping factor.
David.
David.
I squared R is the Voltage Loss! Not the power loss. Power loss also requires knowing the speakers impedance. With your 6 ohm DC load then .74 ohms would cause a 1db loss. That is 54' feet of 18 gauge. So your guess about significant length is not too bad.
So the home theatre folks who claim you should use equal lengths for stereo imaging are not nuts. They are just using too thin of a wire. Since I have seen supplied, by the manufacturers of low end home theatre, 22 gauge wire a difference of 23' feet will be heard by most folks. Place your TV in a corner and allow for up and down on the cable path, voila unbalanced stereo!
The skin depth for 10 gauge cable is 2600 Hertz! Maybe you think that is RF but most do not.
I understand there is way too much fertilizer on this thread but you might want to pinch your nose and wade through it. There is some useful material here.
