Howdy folks.
Can anyone answer my question?.........
I've narrowed down 2 caps for analogue output coupling in my CD6003, now should I use WIMA MKS or Ampohm Polypropylene? I'm going for 47uF's.
Not that it makes a difference but the WIMAs are cheap at under £2 each and the Ampohms are £5.50.
They said they went bust, but since then I saw new series mylar & foil in oil out there. Maybe they did not bite the dust in the end?
You probably mean 4.7uF
The Ampohm are much nicer than any Wima and especially an MKS.
Forgot the dot, yes 4.7uF.
- Design & Build
- Parts
- WIMA MKS or Ampohm for output coupling?
