Hi all. Can someone tell me if the dial lamps are in a type of circuit that when one burns out, it increases the voltage to the remaining three bulbs, and so forth. Thank you. John.
I have a TU-717 and the dial lamps are all wired in parallel, off of an 8V secondary winding of the transformer. Mine were burnt out so I just replaced them with white light LEDs.
Rob
Rob
Rob
How you do it? with one diode it is around 6vdc ?
