Shigaclone transport Gallery
Here you have my Shigaclone.
Rudy
This is the power supply for the shigaclone and the DDDAC.
OPEN-CHASSIS TRANSFORMATOR 100VA 2 x 9V 5 volt for the Shigaclone board
OPEN-CHASSIS TRANSFORMATOR 100VA 2 x 12V 8 volt for the trichord clock 4
OPEN-CHASSIS TRANSFORMATOR 100VA 2 x 12V 8 volt for the 2 CD motor
OPEN-CHASSIS TRANSFORMATOR 500VA 2 x 12V 12 volt for the DDDAC.
1 ALWSR+ B&T ALWSR +5v Built & Tested Regulator - Shigaclone Board
1 ALWSR+ B&T ALWSR +8v Built & Tested Regulator - Trichord clock 4
Rudy
Hello all,
After lurking a long while, I've finally started working on a Shigaclone following Peter's advice. Here's the result. Not as beautiful as some of the masterpieces, but decent for me and singing from the first time !
There's room for improvement. The clear acrylic needs to be matted. The NC door switch needs a better one. The caps are Elna Silmic II, since I couln't find BG for a decent price.
Thank Peter and all the contributors. The shigaclone is a real pleasure.
Stephen
Rudy
Beautiful build, wow really fantastic looking player ! Have you had a chance to compare it yet ? What level CD player will these clones compete with ?
regards,
Another example of Peter's superb work. I asked him to make me a Shigaclone chassis using Canadian maple and I think it really works well. Finished to an absolutely perfect standard. All I had to do was trim the diplay panel, solder up the buttons, replace one cap on the transport mechanism, add the SPDIF resistors and fit it all into place. It sounds - and looks - superb! 😀
