Beautiful Swingin' Speaker
Graaf, your pix did not open for me...
one more try, the grey thing around the speaker is the gel cushion
best,
graaf
Here are the formulas for calculating TSPs:
HAUPT
For the bass section I would ask for "free air" woofers in a car hifi forum.
That's a generous assessment of car fi. Any time I try digging for drivers which have meaningful specs I end up looking at European parts. Thanks for the pointer; TspCheck defines Qms and Rms as reciprocals of each other moderated by a constant---Qms = 2 pi Fs Mms / Rms---so calculation's easy enough. Most of the drivers with Qms > 10 have quite light cones, however.
After some consideration I'm inclined to use an 8 inch midbass instead of a 10 inch. Means moving the low crossover up to 150-200Hz in exchange for improved dispersion at the high end, which I'm fine with, and I like the aesthetics better. The drivers I keep coming back to are Peerless and Selenium, specifically the 830869 and 8MB4P. The 830869 has both a lower Qms (5.7) and a lower Rms (1.01) than the 8MB4P (10.6 and 1.23). It's also longer throw so it crosses lower more easily and has a flatter SPL, so I'm leaning towards the 830869. Any thoughts on which would integrate better with a Neo8? What caught my eye is 830869's Rms is close to the 8W4P Michael's using but the Qms is less than half of the 8W4P's.
I will do a new measurement tonight. 🙂
Cool, thanks.
Haha. That was actually "Walter" (John Goodman) from the movie "The big Lebowski"....
I'd made the same assumption. Now I'm wondering if you actually look like your speakers after all.
And here's the measurements I promised. The upper trace is 2 cm from the Excel W15CH001 driver, the lower is taken on-axis at 1 meter. It looks like the dipole peak is at 1630 Hz. I did a measurment at 90 degrees as well that verified this.
The calculated value based on the chassis diameter is 1750, the real value 1630. That just 7% off.
I actually use two of these drivers, mounted closely. Interesting to see that this arrangement does not change the dipole peak.
No comb nulling
Interesting that there is no hint of comb nulling above the peak. The response is very even on both sides. Also, how the metal cone ringing changes from triple peaks to an easy Q, symmetrical hump. Nude dipole really measures excellent.
Cool. Am I correct in assuming the calculated value is from Edge?
I wouldn't expect to see much; real drivers are large enough there's plenty of path length diversity. I am somewhat surprised at how smooth the curves are.
My calculated values are from EDGE, yes. Great tool by the way.
This mids measures smooth indeed, its the best I've seen myself so far. That 1 meter measurement is smoothed 1/3 octave though (sorry - force of habit...) There's a new graph below without any smoothing! Its shows that the breakup ringing is still there at 1 meter, but its still remarkably smooth around the dipole peak at at lower frequencies.
So, after some more investigation, it seems I have the space for a single 15 inch woofer and the Edge based method we've come up with in the last page or so indicates a pro 8 inch driver should provide sufficient SPL as well. So, instead of the 830869 and 830669, I'm looking at using the Selenium 8W4P and 15PW5 crossed around 150Hz. However, I notice the datasheets for both of these drivers show rather odd free air phase behavior around Fs.
StigErik, have you seen any drivers with similar behavior? I've a certain skepticism about the data as the resonances I've seen all have symmetrical peaks around a wrap through 180 degrees. But my experience so far is datasheets are remarkably good predictors of actual behavior. Neither Allocator or PLParEQ are capable of correction in this case. While I'm sure there's a suitable phase shifter VST plugin to fix things up somewhere I haven't found it yet. Hence, I've a certain concern over using the Selenium drivers.
