Rockford Fosgate P10002
Hello everyone I'm new to this electronic repair, so I'm kinda lost on were I should begin testing the amp in order to fix it. The reasons I wanna repair the amp myself is 1) save money, and 2) I wanna learn how. Now the problem with my amp is one channel plays but the other does not play any audio, but it does send out a signal that causes my subs to smoke. When it stopped working I had the amp bridged playing clean and awesome. And when the channel blow it also fried the voice coils on my subs. For the life of me I can't figure why it blew, or what's wrong with it. I don't see any physical damage, soot (sp?), or melt downs. Any help will be greatly appresiated. Thank you
i have a multimeter (fluke), and i read the site and checked the transistors like it said, and they all failed two of the three test. because of this im kind of doubtful i did it right because one channel still plays and the amp doesn't go into protect mode or anything, but the test tells me their all defective. thank you for your help perry
Q1028 - 36P15 - 2.26 (slowly decreases)
Q1022 - 36P15 - 2.421 (slowly decreases)
Q1025 - 36P15 - 1.575 (slowly decreases)
Q2028 - 28N15 - 00.2
Q2024 - 36P15 - 1.63 (slowly decreases)
Q2029 - 36P15 - 1.822 (slowly decreases)
Q2020 - 36P15 - 2.045 (slowly decreases)
There is only one 28N15 and the rest are 46N15. I tested them with the fluke set to ohm like the basic transistor testing says to.
Yes. Q2028 is shorted but you should have three N-channel FETs and three P-channel FETs in each channel. What are the following transistors?
Q1026
Q1029
Q1031
Q2021
Q2025
Is the amp below the same as yours?
Q1026 - 46N15
q1029 - 46N15
q1031 - 46N15
q2021 - 46N15
q2025 - 46N15
Yes my amp looks just like it, but at the bottom of the board underneath were it says Rockford Fosgate it says P1200.2 instead of P1000.2. Pics below
Q1026 - 46N15 - 5.77k (and rising)
Q1029 - 46N15 - 5.77k ohm (same)
Q1031 - 46N15 - 5.63k ohm (same)
Q2021 - 46N15 - 45.3
Q2025 - 46N15 - 45.3
resistors
R1093 - 0.3
R1100 - 0.3
R1107 - 0.4
R1099 - 0.3
R1081 - 0.3
R1092 - 0.3
R2081 - 0.3
R2092 - 0.3
R2099 - 45.4
R2091 - 0.3
R2105 - 0.2
R2079 - 0.3
